Thread: pd170 bottom end whine
  1. pd170 bottom end whine
    Jan 2023
    devon
    Hey guys, bit of a tricky one here! going to try explain in as best detail as i can!.
    2007 b6 passat, pd 170 engine, saloon.
    stage 1 remap, dpf and egr delete
    after experiencing some running issues, i took the car to my local garage and the problem was found and repaired:
    Cam sensor replaced
    Rear fuel pump replaced
    full service
    Egr stuck open, blank plate applied
    Car ran amazing for 2 days commuting to work.
    woke up the following morning, started the car and then came a really high pitched whine in sync with the rpm from idle all the way up through the revs.
    Here is what the mechanic tested and is NOT the problem:
    Cam belt tension
    All tensioners
    aux belt, still makes sound with it off
    turbo
    all cam belt area bearings
    After those tests, we discovered the noise is coming from the bottom end, inside the engine.
    sounded like possible oil pump, replaced with a whole new unit and the noise is still there.
    3 mechanics have looked at it and all have failed to find the issue.
    when i looked last night, i noticed there is a lot of gases escaping from the oil filler hole when you tske the cap off. if you rest the cap on the hole and run the engine, the cap bounces around like crazy indicating too alot of pressure or gases escaping to there?
    any advice would be massively apreciated. please do not get distracted thinking it is top end or turbo because that has been ruled out by 2 mechanics.
    video link of the noise: pd170 bottom end internal whine noise
    funnily the car is actually running the best it ever has been, full power and has plently of torque. no tapping or knocking.
    im completely stumped, any help would be amazing right now!
    only option ive been given is a new engine which is not ideal.
  2. Re: pd170 bottom end whine
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    You likely have a gear driven balancer unit and it could be related to that. Perhaps the gearing is too tight between the crank cog, intermediate cog and the driven balance shaft cog. If it is a chain driven balance unit it could be a slack chain drive or worn chain tensioner. Perhaps something internally has worn in the balance unit to the point it is complaining.
    Could also be a worn timing tensioner, or timing belt rubbing on something. Cams look OK? No marking or signs of contact at non contact points? AC compressor in good health if you have AC? Some Passats have constantly rotating compressors that utilise a swash plate changing the angle to promote pumping of the gas and levelling to cease pumping. These do not have traditional magnetic clutches to switch AC pumping on or off, it is basically on all the time but either active or inactive.
    All need to be checked.
    Finally it is illegal to drive a car that has had emission control parts removed or 'deleted' from operation. Oddly it is not illegal to remove or delete these parts, just to drive the car once it has been done. And we know the engines supposedly run better and are perkier etc., etc., but altering them like this increases nitrogen oxides NoX gases 40 fold, which is an invisible killer in built up urban areas especially affecting children who develop lung issues as a direct result. Some altered engines have prematurely failed after emissions parts were removed. My 170 has stock DPF, stock EGR blows way under the 0.50 VIN plate in the irrelevant MOT smoke test (it is a NoX test that is needed) and goes like a bat out of hell still at 232000 miles. No excuses for removing these parts imo.
    Mad Mitch
  1. Question BRD PD170 Issue
    By LavaGreyB7 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-11-2020, 07:53 PM
  2. Pd170 upgrades
    By stevec33 in forum 1.9TDi - Engine
    Last Post: 07-02-2016, 10:02 AM
  3. Question A3 PD170 Intercooler
    By NickA3S in forum 2.0TDi - Engine
    Last Post: 08-05-2015, 08:28 AM
  4. A4 facelift flat bottom steering wheel with TT flat bottom airbag?
    By hsmithboy30 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-11-2014, 12:34 AM
  5. PD170 Gear Box Oil
    By jonny_frs in forum Golf MK5 - 2004 - 2009
    Last Post: 25-01-2013, 12:16 AM
