Thread: Audi A5 Cabriolet Battery Drain
  1. Audi A5 Cabriolet Battery Drain
    Jan 2023
    Bucks, UK
    My first post, and it's a solution so I hope it helps someone.
    Have a 2009 Audi A5 Carbriolet which suddenly had a total battery drain. Only other clue was the high-level brake light on the boot was on all the time (when the battery was charged).
    Have seen lots of threads here covering issues similar to this, but none of them solved the problem. The main issue was related to the fact it was a soft-top which had leaked!
    Had removed every single fuse (individually) to try and isolate the problem without success. There are 4 fuse boards in the A5 (5 if you include the ones on Terminal 30 on the battery).
    So a fully charged battery was giving 5 amps of drain after all the circuits had shutdown. It's over 12 amps before that happens.
    Discovered that moving the loom near the fuse-board changed the current drawn by around 1-2 amps. On unwrapping back a large section of cloth on the loom, discovered that Audi seem to be joining high current cables within the loom. Two of the high current connections appeared eroded. Then I noticed a green copper deposit on the chassis towards the rear of the car. So it looks like the copper was electroplating onto the chassis via the damp in the loom and water held in the sound proofing (a sponge!).
    So, I had to re-join the connections. On the basis the existing method used didn't work I potted them in something non-conductive and ensured they pointed up so that moisture could not drop down into them.
    This all seems to have worked (see pictures).
    Hope this helps someone as it took a really long time to get to the bottom of it.
    WhatsApp Image 2023-01-10 at 16.01.02a.jpgWhatsApp Image 2023-01-10 at 16.01.02b.jpg
  2. Re: Audi A5 Cabriolet Battery Drain
    Aug 2015
    Cambridgeshire
    Thanks for sharing
  1. Battery Drain or faulty battery/alternator?
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-11-2018, 12:47 PM
  2. Electrical Fault - car not going to sleep mode - Battery Drain Audi A4 2007
    By willywill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-09-2018, 09:51 PM
  3. Please Help Audi A6 Battery Drain
    By tyro in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-04-2016, 08:13 PM
  4. Please Help Audi A3 2006 TDI 2.0 Battery drain
    By kma01 in forum Chat - Anything with wheels
    Last Post: 23-01-2013, 01:32 PM
  5. Please Help Audi 80 - Battery Drain, Oil Sensor and Rev Counter Issues
    By l_grundy in forum 80 - 90
    Last Post: 29-09-2008, 10:44 PM
