Thread: 2.0 tdi bkd engine cuts out in drive and just cranks afterwards
  1. Unhappy 2.0 tdi bkd engine cuts out in drive and just cranks afterwards
    Jan 2023
    kimberley South Africa
    Hello Guys, so my bkd engine just dies on me in the drive and just cranks afterwards, ive been dealing with this issue for long now. we have done the timing and replaced new cambelt, reconned the turbo, checked the injectors, in good condition, replaced the tandem pump, changed the fuel pump relay, changed the water temp housing. we have done absolutely everything to try and resolve the issue but no luck, diagnostics throws out no errors, tried resolving every mechanical issue that could also play a role still no luck, what could the issue be? we're out of options
  2. Re: 2.0 tdi bkd engine cuts out in drive and just cranks afterwards
    Mar 2010
    Derry ireland
    67 Post(s)
    When you turn ignition on you should here your fuel pump priming the system up i ask this question because theres 2 fuel pumps relays on this model that are inter connected at ecu pin nos a52 (switched earth) The most likely cause of your problem
  1. Audi A4 B8 2011 CAHA engine cranks but doesnt start?
    By hussnainh8 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-08-2025, 05:28 PM
  2. Engine cranks but will not start
    By Seat Driver 1 in forum Alhambra
    Last Post: 22-10-2011, 09:36 PM
  3. Question Engine cuts out
    By Threadonaspool in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-01-2009, 10:28 PM
  4. Engine Cuts Out
    By adunky in forum Chat - Anything with wheels
    Last Post: 10-04-2008, 08:44 AM
  5. engine cuts out
    By muplin in forum Golf MK4 - 1999 - 2004
    Last Post: 28-12-2007, 11:04 AM
