Thread: 05 sharan 1.9 tdi airbag fault.
  1. 05 sharan 1.9 tdi airbag fault.
    May 2010
    edinburgh
    Hi all, airbag light came on, scan shows it's the passenger seat. I have seen a lot of posts for other vws having an issue with the connector under the seat, which can be rectified by removing the connector an splicing the wires. Can anyone confirm if this applies to the Sharan? Many thanks in advance as always
  2. Re: 05 sharan 1.9 tdi airbag fault.
    131 Post(s)
    1979 Post(s)
    It depends if it is the wires or the bag, I (and VW) don't agree with splicing the wiring
  3. Re: 05 sharan 1.9 tdi airbag fault.
    May 2010
    edinburgh
    Thanks Steve. So it was one of your replies to a similar thread that made me think this was the way to go...Vw have been doing it themselves?! If that's where the problem lies what would you do?
    passenger seat airbag connector fault
  4. Re: 05 sharan 1.9 tdi airbag fault.
    May 2010
    edinburgh
    Anyone else?
  5. Re: 05 sharan 1.9 tdi airbag fault.
    131 Post(s)
    1979 Post(s)
    We get a few where the plugs cause issues, usually Golf 5 side bags and T5 with swivel seats and usually they respond to electrical cleaner spray or replacing the pins both sides with new Gold plated ones but that is tricky as VAG won’t sell the pins and they need a special crimping tool. The value the ECU sees the resistance at is critical.
  6. Re: 05 sharan 1.9 tdi airbag fault.
    May 2010
    edinburgh
    Ok, thank you. I will try cleaning everything and get the code cleared before going deeper. Appreciated.
  1. Airbag Fault after trying to switch back on Passenger Airbag
    By platty25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-08-2011, 10:47 AM
  2. Sharan airbag disabling?
    By 3narf in forum Touran - Sharan - Caravelle
    Last Post: 28-05-2009, 02:42 PM
  3. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
  5. sharan airbag light
    By daddy in forum Touran - Sharan - Caravelle
    Last Post: 16-03-2008, 08:32 PM
