Thread: Actual vs requested boost and P0234 limp mode 2.0tdi
Results 1 to 9 of 9
  1. Actual vs requested boost and P0234 limp mode 2.0tdi
    Sep 2022
    corby
    Today I tried to log Actual vs requested boost,with engine speed (red) and duty cycle with vcds.
    Its a BRE 16v 2.0tdi.
    This is the multitronic gearbox with the 7speed, so the idea was to go from 2000rpm - max, without hitting the kickdown, but it was in 4th, and went to 5th, and then hit limp mode, with a P0234 overboost code again.
    I tried 3or4 times, after clearing the code, and this is the graph I got.
    I have cleaned the turbo with mr muscle, replaced the N75, and had a good xmas day run for about 20+miles at 3500-4000rpm in 4th gear with no problems, so was surprised it went in limp mode today
    Does this graph show anything unusual?
  2. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    134 Post(s)
    1995 Post(s)
    Mr Muscle is water based and causes the turbine shaft exhaust side piston ring to rust and lose oil control, from the graph the turbo needs properly rebuilding.
  3. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    Sep 2022
    corby
    would that mean remove strip and clean, or replace seals,bits,etc?
    I guess you cant tell until its in pieces?
  4. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    134 Post(s)
    1995 Post(s)
    We send them to Midland Turbo for a quick turnaround and faultless rebuild.
  5. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    Mar 2010
    Derry ireland
    67 Post(s)
    The turbo pressure control solenoid is flagging up code po234 over boost. I would start by checking resistance between pins nos 1 & 2 which should read between 14-20 ohms this turbo has a switched earth at ecu no b29 Do not dismiss your fault code
  6. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    Sep 2022
    corby
    *this turbo has a switched earth at ecu no b29*
    Is that from the N75 too?
    Is there something I can check at ECU B29?
  7. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    Sep 2022
    corby
    well its working alright again today, so ***?
  8. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    Apr 2023
    Herts
    Hi all, new to this group.
    I have a VW golf mk5 2.0 GT
    The issue I am having is when over 2000rpm sitting at 70/75 the car goes in to a limp like mode and I have no boost, no lights on dash and when using OBD reader a pending code of PO234 occurs. The fault stops when car is turned off and on again, then the car drives as normal for a while.
    Code says overboost condition
    I have had the car serviced and a refurbished turbo fitted.
    Anyone had this issue occur and had a resolution?
  9. Re: Actual vs requested boost and P0234 limp mode 2.0tdi
    134 Post(s)
    1995 Post(s)
    16618 (P0234) - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    If you have P0234 then either the turbo is still sticking, there is a fault with the vacuum control system or the Manifold Absolute Pressure sensor is sending incorrect information to the ECU.
  1. Question Vw Passat 2.0tdi B6 over boost p0234
    By Topcata380 in forum Chat - Anything with wheels
    Last Post: 29-06-2020, 11:10 PM
  2. Question Turbo Over boost- Limp mode
    By qalaray in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-10-2018, 04:39 PM
  3. Limp mode and over boost
    By Rob_2i in forum VCDS - Help Requests
    Last Post: 07-12-2014, 10:44 PM
  4. Please Help No turbo boost, limp mode
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2012, 08:41 PM
  5. Please Help boost cutting out and limp mode
    By 90karl90 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-05-2009, 06:18 PM
