Thread: A4 B6 Heater Blower motor.
Results 1 to 10 of 19
  1. A4 B6 Heater Blower motor.
    Nov 2016
    Southampton UK
    Hi, If you see this CRASHER, you kindly gave me the part number for that throttle potentiometer. It's been fine thanks.
    It's bluddy freezing so having changed the thermostat I need to replace the blower motor. Loads on ebay, usually 8E282002IE? Would you have access to the part no. for that? Dealer won't divulge.
    Thanks...... Did you sort it with Audi Tradition?
    Might be of interest that I got another rear bulb housing after my other problems, but fixed the old one just by very slightly bending the connection pins with long nosed pliers.
    02 A4 B6 Avant RX52 YTS Cheers.
  2. Re: A4 B6 Heater Blower motor.
    Sep 2020
    South Yorkshire, UK
  3. Re: A4 B6 Heater Blower motor.
    Nov 2016
    Southampton UK
    Thanks Larhal, you're a star. It was listed on the first link you sent. 8E1820021E. Identical to the numbers on those for sale except they don't include the first '1' ?.... I'll probably order one anyway unless anyone tells me different? Thanks again.
  4. Re: A4 B6 Heater Blower motor.
    Sep 2020
    South Yorkshire, UK
    Keep the second link as it is invaluable tool for our parts.
    Make sure you get the one for RHD, that would start with 8E2
  5. Re: A4 B6 Heater Blower motor.
    Nov 2016
    Southampton UK
    That accounts for the '1' in the German? parts list then? Many thanks L. I've ordered one on ebay now. Fingers crossed. I can almost handle the cold, but the condensation/ice on the screen has been a nightmare.
    Crasher, I've seen you've got 'tradition' up to speed, well done!
  6. Re: A4 B6 Heater Blower motor.
    Nov 2016
    Southampton UK
    And so it goes on.......... Fitted new thermostat, coolant and now the blower motor. That works well but no heat.
    Any ideas what's next? I'm guessing the heater matrix or supply/outlet is blocked. Can it be flushed reasonably easily?
  7. Re: A4 B6 Heater Blower motor.
    Sep 2020
    South Yorkshire, UK
    Yes it can be flushed easily. Also do you have heat when your engine is above 2500 rpm? If so you need to bleed the heater core.
    Heat's baaaaack!! Maybe this time for good.....
  8. Re: A4 B6 Heater Blower motor.
    Nov 2016
    Southampton UK
    Thanks L. I was intending to give it a thrash on the m/way this afternoon anyway to see if there were any signs of heat coming through.
  9. Re: A4 B6 Heater Blower motor.
    131 Post(s)
    1978 Post(s)
    Quote Originally Posted by monzaz View Post
    Yes all sorted up and running, customs clearance registered, bank transfer payment set up etc. I am going to put an order in about once a month as and when required. The prices you see on there aren't going to come out like that, each time it will depend on the size of the order, I had one order as a trial and it came straight through and the second was a 3K Euro big one and got hit for 300 Euro packing and plus UK duty, VAT, UK delivery etc which totalled about £600 so it will vary, I will take a deposit on order and the remainder on arrival.
  10. Re: A4 B6 Heater Blower motor.
    Nov 2016
    Southampton UK
    Quote Originally Posted by Larhal View Post
    Gave it large on the motorway. Temp gauge went up quickly then stayed stable at about 90 degrees. Still stone cold.
    Back to a 'flush' I guess?
  1. Heater blower motor
    By dieselal in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 09-02-2021, 07:49 PM
  2. Heater blower motor
    By nigedvd in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 06-07-2015, 10:43 PM
  3. heater blower motor
    By aaman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-09-2008, 12:26 AM
  4. Heater Blower Motor or something else?
    By Audi 80 Man in forum 80 - 90
    Last Post: 08-01-2008, 06:54 PM
  5. S reg A3 - Accessing Heater Blower Motor
    By kimi in forum Audi A3 - Archive Topics
    Last Post: 26-10-2007, 10:54 AM
