Thread: Coding in a new battery
Results 1 to 10 of 13
  1. Coding in a new battery
    Feb 2014
    Hertfordshire
    Would somebody be able to point me in the right direction (tried a search but couldn't find), please? I need a new battery for my A6 C6 (2L TDI), and remember about it needed to be coded in? Is that possible with VAG cable? Any instructions would be greatly appreciated! Many thanks!
    2009 A6 Avant (C6) SE 2.0 TDI 136HP multitronic
  2. Re: Coding in a new battery
    Jul 2008
    Lisburn
    16 Post(s)
    on the C6 some BCMs do and some dont. i see you have a face lift so gonna take a stab in the dark and say you do.
    VAG com will do it - did you try the ross tech website?
    but i am also going to say as long as you replace like for like you will get away without coding, the BCM will learn the new battery -
    think about winter driving vs summer driving different demands on charging.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Coding in a new battery
    131 Post(s)
    1973 Post(s)
    All the coding does is tell the Battery Monitoring Unit the battery has been replaced so that its learnt values are erased so it does not overcharge the new part. When fitting a Varta (all we will fit) we find the serial is one digit too long but as long as the brand code and size are correct, all you need to do is chnage the serial by one digit or however much of the serial you can enter.
  4. Re: Coding in a new battery
    Feb 2014
    Hertfordshire
    Many thanks for the help. Do you find Varta to be a great alternative to what Audi sells for a fortune, or it's more about the system recognizing it well? I was looking at Varta, but a Bentley mechanic mentioned to me that they are super happy with Exide batteries (bit dearer than Varta or Bosch).. Tx
  5. Re: Coding in a new battery
    131 Post(s)
    1973 Post(s)
    All modern batteries are ****, especially AGM types. Exide are fine, we are happy with Varta but even one of their 096 AGM's fell over and died within a month on our loan car Passat. The worst by far in our experience is Yuasa with the 5000 series EPB version being awarded a Gold medal for failure as EVERY single one we fitted failed as did their replacements.
  6. Re: Coding in a new battery
    Feb 2014
    Hertfordshire
    Many thanks for the replies! Had a look, but for me the '61 - Battery regulator' panel doesn't show up when I connect the VAG Com, so this should mean that it is not designed with coding in? Many thanks
  7. Re: Coding in a new battery
    131 Post(s)
    1973 Post(s)
    What is the VIN?
  8. Re: Coding in a new battery
    131 Post(s)
    1973 Post(s)
    To illustrate my opinion of modern batteries, I changed one on a 2007 Golf 5 yesterday, it was the factory fitted original and was just starting to get a little sluggish... 16 years old!
    @szladob Your car has a J367 battery monitoring unit 8K0 915 181 C on the earth cable with a comms line to the CAN BUS unit address 19 on the blue wire but not the J644 type mounted to the rear panel which must be coded in address 61
    This is the VCDS procedure Battery Replacement - Ross-Tech Wiki
  9. Re: Coding in a new battery
    Feb 2014
    Hertfordshire
    That's very helpful, many thanks! I'll try this 19 CAN gateway, as I don't have the 61 (5F, 62, 6D is the order). On a separate note, may I ask if there is a way to reset the rear wiper? It got wet somehow inside, which was probably what giving a hard time to my old battery (13 year old) - did open the lid cover inside, dried things, and battery is now happy (also being warmer now in our area) but the wiper still has it's own mind - starts on its own, stops, in the wrong position, etc..
    Many thanks again for all your valuable help!
  10. Re: Coding in a new battery
    Feb 2014
    Hertfordshire
    Many thanks for the help. Finally managed to get to replacing the battery, which seems to operate OK (few error messages popped up (tyre monitoring, ABS), but seems I got over those now. However, the coding in didn't work out at all.. I have found the long code under CAN 19, channel 4, but when I put in the new long code, hit test, it just displays the old code, and the save button doesn't light up. The battery is a I1 from Varta, same size as the one that was in there - BEM code sticker on it says: 8K0915105F MLA1809088QS9, which is not exactly what VDCS showed: 8K0915105F MLA 080908QS9F.
    The data of the new Varta are:
    Brand Varta
    Product Code I1
    DIN 610 402 092
    Range Varta Silver
    Voltage 12 Volts
    Technology Wet
    Capacity (C20) 110 Ah
    CCA (EN) 920 A
    Length 393 mm
    Width 175 mm
    Height inc. terms 190 mm
    Other References UK Ref 020, 610402092, 610 200, VW 1J0915105AK
    Guarantee 5 Years
    Barcode (EAN) 4016987119587
    I have tried to enter 1J091505AK VA0 6987119587, but no luck.. Tried also with the 610402092 number, and different parts of the EAN number (this should be the serial number, right?)
    Any advice would be greatly appreciated. While the car seem to operate OK, I do have weird errors popping up in the scan that keep returning even after clearing them.
    Many thanks!
  1. Question AGM battery coding
    By Scottiedogg in forum Golf MK7 - 2013 - 2019
    Last Post: 24-11-2020, 09:53 PM
  2. Coding a new battery
    By 54A4Avant in forum VCDS - General Questions
    Last Post: 04-01-2018, 08:14 PM
  3. Question Help coding new battery
    By Darks in forum VCDS - Help Requests
    Last Post: 28-09-2017, 09:38 PM
  4. Battery coding
    By glh-ronin in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2016, 11:06 PM
  5. Please Help Battery coding
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2013, 07:42 AM
