Thread: Gearbox software update
Results 1 to 10 of 18
  1. Gearbox software update
    Jul 2010
    lichfield uk
    Hi anyone know place in Midlands or someone with Odis software where I could update my gearbox software to the latest version ? I'm getting P284A code error from time to time only when I'm reversing, once I restart the car error clear it's self end I can reverse without any problem. So before I start throwing money into the mechatronics and clutches I try to update my gearbox first. According to my research I'm on the original software and there's 3 more updates.
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 4G1 927 156 T HW: 0B5 927 156 J
    Component: 0B5 30 TDIRdW H01 0006
    Revision: --H01---
    Coding: 000001
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_TCMDL501021 001012
    ROD: EV_TCMDL501021.rod
    VCID: 3E738BFFA177BCBFAB-806A
  2. Re: Gearbox software update
    132 Post(s)
    1980 Post(s)
    18051 (P284A) Shift Fork 2 - Stuck
    0B5, an absolute nightmare of a gearbox, no software update will help; a fluid change MAY.
  3. Re: Gearbox software update
    Jul 2010
    lichfield uk
    Yes that's my plan of action oil change with both filters and software update
  4. Re: Gearbox software update
    132 Post(s)
    1980 Post(s)
    It depends if there is one, do you know the current version number?
  5. Re: Gearbox software update
    Jul 2010
    lichfield uk
    I believe It's the first version 0006
    According to this website
    https://vag-flashinfo.de/site/index?partno=4G1+927+156+T
  6. Re: Gearbox software update
    132 Post(s)
    1980 Post(s)
    You need to know from a code scan.
  7. Re: Gearbox software update
    Dec 2022
    Birmingham
    I'm having the same issue in the westmidlands took it to a gearbox specialist and they tried to do the update but said Audi is the only one who can access my ECU. Audi insist I pay £150 for a diagnostics and have never heard of an update allegedly. It's an Audi A5 2010 stronic it's a jerky change from 2-1 and I keep getting a warning message about reduced torque due to overheating and it's jerky on some pull offs etc it's very temperamental and sometimes delayd in gear changes.
  8. Re: Gearbox software update
    Jul 2010
    lichfield uk
    This is the scan from my car and to my understanding software version is :H01 0006
    Sunday, 17, January, 2021,14:21:00:00009 VCDS Windows Based VAG/VAS Emulator Running on Windows 7 x
    VCDS Version: 19.6.1.0
    Data version: 20190529 DS308.0 Ross-Tech: Home
    VIN: WAUZZZ4G8DN126962
    License Plate:
    ControlModule Part Number:4G1 927 156 Component and/0B5 30 TDIRdW
    Version:H01 0006
    Software Coding: 000001 Work Shop Code: WSC 02391
    Advanced Identification/FAZIT
    Identification: TFK-030 Revision: --H01---
    Date: 20.02.13
    Manufacturer number: 0904 Test stand number: 0255
    Flash Status
    Programming Attempts (application): 1/1 Successful Attempts (application): 1/1
    Programming Status: 00000000
    Flash Date: 13.03.18
    Flash Date: 0000.00.00 Flash Tool Code: 00000 000 00000
    Software
    UDS: 02.00.03
    ISO15765: 02.00.01 CAN: 02.14.02
    HiSpd Net: 01.06.00
    Misc.
    Hardware number:
    0B5 927 156 J
    Workshop System Name: J217
    ASAM Dataset: EV_TCMDL501021 ASAM Dataset Revision: 001012
    Car Info
    Chassis Number: WAUZZZ4G8DN126962
    VCDS Info:
    Labels: 0B5-927-156.clb ROD: EV TCMDL501021.rod
    18:47:09:00009 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7
  9. Re: Gearbox software update
    Jul 2010
    lichfield uk
    I think with Odis engineering you can update your components once you got the update files on your laptop.
    My gearbox upshifts are seamless there is only slight harshness when downshifting from 3-2 and also P284A code when I'm reversing from time to time.
    Start with scanning your car, is there any fault codes in TCU
  10. Re: Gearbox software update
    132 Post(s)
    1980 Post(s)
    @marciolo that is if you can get ODIS engineering, they won't help me get it! Your car has a gearbox oil change on 2020-07-25 at 69699 miles by Tamworth Audi, unless I am going blind I can't see the software version
    There is this TPI but you have a specific code, there are numerous 0B5 TPI's for all sorts of errors (the 0B5 is a piece of junk) but none that I can see cover P204A.
    Technical product information Transaction No.: 2038130/2
    Hard jerk when pulling away after start-stop and hard knock with 2-1 gear change - 0B5 gearbox Release date: 15-Dec-2014
    Customer statement / workshop findings
    When restarting the engine after a stop-start operation the vehicle pulls away with a one-off hard jerk/knock.orA one-off hard jerk/knock when changing from 2-1.
    Technical background
    No entry in diagnosis address 01 and 02.
    Production change
    Measure
    Try to reproduce the customer complaint so that it can be clearly assigned to this TPI. The following measure must only be carried out, if all the criteria (model/type, chassis number, engine/gearbox code, PR number(s), part number, software version etc. ) match exactly. Otherwise this solution won't work and repeat repairs may be necessary. In such a case, we may reject the warranty claim and redebit the parts.Update the gearbox control unit with SVM code02A089:
    Actual control unit
    Required control unit
    Hardware
    Software
    Version
    Hardware
    Software
    ≥Version
    0B5927156J0B5927156K
    8K9927156M
    8K9927156M
    0005
    8T0927156E
    8T0927156E
    0010
    8T0927156G
    8T0927156G
    0005
    8T0927156F
    8T0927156F
    0011
    8T0927156H
    8T0927156H
    0005
    8K5927156
    8K5927156
    0010
    8T0927156J
    8T0927156J
    0005
    8K9927156C
    8K9927156C
    0005
    8K9927156G
    8K9927156G
    0005
    8K9927156H
    8K9927156H
    0004
    8K9927156L
    8K9927156L
    0004
    8K2927156J
    8K2927156J
    0007
    8K2927156L
    8K2927156L
    0010
    8K5927156B
    8K5927156B
    0004
    8K9927156D
    8K9927156D
    0005
    8K2927156M
    8K2927156M
    0011
    8K5927156D
    8K5927156D
    0004
    8K2927156K
    8K2927156K
    0007
    8K2927156N
    8K2927156N
    0008
    8K9927156P
    8K9927156P
    0005
    8K9927156S
    8K9927156S
    0005
    8K2927156G
    8K2927156G
    0008
    8K2927156R
    8K2927156R
    0007
    8K2927156T
    8K2927156T
    0007
    8K9927156R
    8K9927156R
    0004
    8K9927156J
    8K9927156J
    0005
    8K2927156P
    8K2927156P
    0007
    8K2927156Q
    8K2927156Q
    0008
    8K9927156Q
    8K9927156Q
    0004
    4G1927156F
    4G1927156F
    0009
    4G2927156L
    4G2927156L
    0005
    4G1927156J
    4G1927156J
    0008
    4G5927156
    4G5927156
    0004
    4G9927156
    4G9927156
    0008
    4G2927156N
    4G2927156N
    0004
    4G1927156T
    4G1927156T
    0008
    4G2927156P
    4G2927156P
    0004
    4G1927156K
    4G1927156K
    0008
    4G9927156A
    4G9927156A
    0004
    4G9927156K
    4G9927156K
    0002
    4G9927156L
    4G9927156L
    0002
    4G1927156L
    4G1927156L
    0010
    4G9927156B
    4G9927156B
    0007
    4G2927156
    4G2927156
    0008
    4G2927156R
    4G2927156R
    0004
    4G1927156S
    4G1927156S
    0013
    4G9927156C
    4G9927156C
    0006
    4G1927156Q
    4G1927156Q
    0008
    4G5927156A
    4G5927156A
    0004
    4G2927156D
    4G2927156D
    0008
    4G9927156D
    4G9927156D
    0004
    4G2927156E
    4G2927156E
    0008
    4G9927156E
    4G9927156E
    0004
    4G1927156R
    4G1927156R
    0009
    4G9927156G
    4G9927156G
    0004
    4G2927156F
    4G2927156F
    0008
    8R1927156R
    8R1927156R
    0006
    8R1927156L
    8R1927156L
    0005
    8R1927156S
    8R1927156S
    0008
    8R2927156
    8R2927156
    0005
    8R1927156N
    8R1927156N
    0006
    8R1927156H
    8R1927156H
    0004
    8R1927156P
    8R1927156P
    0007
    8R1927156J
    8R1927156J
    0004
    8R1927156Q
    8R1927156Q
    0006
    8R1927156K
    8R1927156K
    0004
    8R2927156N
    8R2927156N
    0006
    8K2927156E
    8K2927156E
    0008
    4G9927156F
    4G9927156F
    0004
    8R2927156L
    8R2927156L
    0004
    8R2927156M
    8R2927156M
    0004
    8K9927156B
    8K9927156B
    0004
    8K9927156E
    8K9927156E
    0004
    8K9927156F
    8K9927156F
    0004
    Warranty accounting instructions
    Service number/damage code: 3730 / 0041Accounting with APOS:
    Model:
    Repair operation:
    Designation:
    Time units:
    27068950
    Charge battery
    10 TU
    01510000
    Software update
    TU according to diagnosis log
    The times of this TPI are correct at the time of publication.Accounting with APOS/2:
    Illustration:
    Position:
    Number
    Designation:
    Activity
    Time units:
    STA-02
    Battery
    90
    10 TU
    STA-02
    1
    S00042
    Software update
    A8
  1. Replies: 1
    Last Post: 01-10-2020, 05:01 PM
  2. Question How to update MMI software
    By safisher2001 in forum In Car Entertainment
    Last Post: 13-03-2015, 10:35 AM
  3. How To Sat Nav software update
    By DukeofWhiteley in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-02-2015, 09:46 PM
  4. who can do a gearbox software update in birmingham?
    By skans786 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-04-2013, 11:43 PM
  5. Gearbox software update tricore ecu lock.
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-06-2011, 01:13 AM
