Thread: VCDS Requirement - based in Solihull
Results 1 to 1 of 1
  1. VCDS Requirement - based in Solihull
    Dec 2019
    Solihull, England
    VAG-COM/VCDS. Does any body have a VAG-COM / VCDS that I can use?Basically, I had the DPF light come on 2 weeks ago, after lots of local trips. Was meaning to take the car onto the motorway to allow the DPF to regenerate, but never got a chance. It's now gone into limp mode with flashing glowplubs and EML. I've ordered a DPF cleaner to spray into the DPF. So once it's out of limp mode, I can drive it at high revs for 30 mins, to force regeneration of the DPF. Hence why I need a VCDS to take it out of limp mode.Failing this, I will take it into a garage, but was looking for a quick easy solution.Thought I'd check if anybody had a VCDS i could use first?
    Many thanksRavi
  1. Question Recommended Specialist near Solihull
    By StuFowler in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 22-02-2016, 07:36 PM
  2. VCDS Request - Audi A3 3.2 based in Ipswich
    By cegeorge in forum VCDS - Help Requests
    Last Post: 08-12-2013, 12:42 PM
  3. Question Labour requirement to replace a/c compressor
    By jgoodman00 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-07-2009, 01:33 PM
  4. 1.9TDi - Requirement to replace gearbox
    By p1234b in forum Golf MK4 - 1999 - 2004
    Last Post: 05-10-2008, 06:10 PM
