Thread: Camshaft possition sensor (g40) implausible signal
  1. Camshaft possition sensor (g40) implausible signal
    Nov 2022
    Bulgaria
    The engine is BKD we checked the wires from the sensor harness to the ECU and with IGN on we get 5 volt on first pin and third and also 5 volt on the middle one.The crankshaft sensor is new original one the camshaft sensor is also new the timing was check 5 times and redone 3 times .The car start with the camshaft sensor disconected but it runs very rough after conecting it doesn't start and VCDS says "Camshaft possition sensor (g40) implausible signal" with connected sensor and "Camshaft possition sensor (g40) implausible signal intermitent" with disconected sensor.Any ideas ?
  2. Re: Camshaft possition sensor (g40) implausible signal
    134 Post(s)
    2021 Post(s)
    I see this A LOT, implausible signal means the ECU can see the signal but it does not like it in comparison to the G28 crank speed sender signal, what is the Torsion Value?
  3. Re: Camshaft possition sensor (g40) implausible signal
    Mar 2010
    Derry ireland
    67 Post(s)
    cam position sensor
    terminal 1 5vs via ecu b2
    terminal 3 switched earth ecu b12
    terminal 2 ecu b28 return signal wire to b28
    Crank sensor terminal 1 5vs via ecu no b42
    terminal 3 earth via ecu b57
    terminal 2 return signal wire to b58 on ecu
  4. Re: Camshaft possition sensor (g40) implausible signal
    Mar 2010
    Derry ireland
    67 Post(s)
    correction the cam position should read ecu no should read b28
  5. Re: Camshaft possition sensor (g40) implausible signal
    Aug 2007
    Derbyshire
    Did you sort this? If not I had a similar issue with a BXE (1,9tdi). If it's the same the issue turned out to be the 'impulse wheel?' that turns with the camshaft. One of the 'tabs' had been slightly bent (by some careless mechanic before me) causing the implausible signal. Once straightened all was fine. It took me a long time checking, testing, swapping before I finally worked this out.
    1 1 0
  1. Replies: 14
    Last Post: 07-10-2023, 12:01 PM
  2. Nox Sensor (G295) Implausible Signal P1071
    By sam8888 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-07-2020, 07:17 PM
  3. Mass Air Flow Sensor: Implausible Signal Polo TDI
    By Dsldude in forum Polo - Derby - Lupo - Fox
    Last Post: 06-04-2017, 12:47 PM
  4. Audi A4 2.0 TDI BPW Cab - G28 Engine Speed Sensor Implausible Signal
    By brasiliangringo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-11-2015, 11:19 PM
  5. Please Help 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    By SkipFeeney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2012, 08:44 PM
