Thread: Strange idle noise from SQ5 2016
Results 1 to 10 of 10
  1. Strange idle noise from SQ5 2016
    Oct 2022
    London
    I have a strange noise when vehicle returns to idle after deceleration. This is intermittent and only happens sometimes.
    Refer to video here: Audi SQ5 Plus (2016) strange noise at idle - YouTube
    Possibly related but I am not sure, I have these error codes, but with no dash warning lights and the car drives fine.
    • P22D300, Turbocharger Turbine Inlet Valve Struck Closed, Status: Passive/Sporadic
    • P22D200, Turbocharger Turbine Inlet Valve Struck Open, Status: Passive/Sporadic
    In test mode the actuator seems to work fine, however there are some noises when it is manually moved which I am not sure if normal.
    Refer to video here: Audi SQ5 Plus (2016) electronic actuator in operation - YouTube.
    The actuator link arm does not move as smoothly as I would have expected under stationary condition. This may be normal though.
    Refer to video here: Audi SQ5 Plus (2016) electronic wastegate actuator in test mode - YouTube
    I am not sure if the last 2 videos are perfectly normal, and whether the error codes are related to the noise, but I have been trying to diagnose this for some time wioth no luck!
    I have a Autel MP808BT diagnostics scanner, so far only utilised the basic features. Is there guidance for specific tests or readings I could take to help?
    Thank you!
  2. Re: Strange idle noise from SQ5 2016
    131 Post(s)
    1974 Post(s)
    That sounds like the DMF is falling apart, what is the VIN?
  3. Re: Strange idle noise from SQ5 2016
    Oct 2022
    London
    Quote Originally Posted by crasher View Post
    that sounds like the dmf is falling apart, what is the vin?
    wauzzz8r8ga102197
  4. Re: Strange idle noise from SQ5 2016
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    That sounds like something heavy trying to break loose. My initial thought was DMF.
  5. Re: Strange idle noise from SQ5 2016
    Oct 2022
    London
    Is DMF the dual mass flywheel? It sounds more like thumping air coming from the air filter box, but it is very hard to tell, and normally only last for a few seconds. That video was the first time I managed to get to front of car before it stopped, and only happend by leaving in drive with parking brake on. If the DMF any pointers on how to diagnose further?
  6. Re: Strange idle noise from SQ5 2016
    131 Post(s)
    1974 Post(s)
    It is a torque convertor on that gearbox, the 8HP55A aka 0BK. The front crank dampers are also a known failure, a noise through the airbox would suggest a cam tarin inlet valve failure which I have not seen on that engine BUT we have seen a lot of problems with those boxes.
  7. Re: Strange idle noise from SQ5 2016
    Oct 2022
    London
    What doe you think about the actuator movement and error codes? Would you guess these are independent of the thumping air noise?
  8. Re: Strange idle noise from SQ5 2016
    131 Post(s)
    1974 Post(s)
    It is possible as the sound could easily travel down the air intake but from a recording it is impossible to say, I would need by head in there and at the moment my right ear is duff anyway.
  9. Re: Strange idle noise from SQ5 2016
    Oct 2022
    London
    An update on this. The previous DTC codes are have been cleared by repairing the actuator but the noise remains and is becoming more frequent. I have now managed to get a recording inside of the intake pipe. Hopefully this offers some more clues? I have driven quite a few hundred miles and there are no current or stored DTCs but the noise is there on every drive.
    Audi SQ5 Plus Edition 2016 strange noise at idle with intake pipe removed - YouTube
  10. Re: Strange idle noise from SQ5 2016
    131 Post(s)
    1974 Post(s)
    The first step is to find out which head the noise is coming from, on Monday remind me and I will check for TPI’s.
  1. Question Laboured engine, Miss-fire, Hesitation? and strange noise at 1200 rpm to idle.
    By simon2609 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-05-2018, 04:53 PM
  2. 2016 A4 - strange sqelching noise when turning - video
    By garmcqui in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 23-05-2016, 10:34 PM
  3. strange idle problem
    By Mr.Gug in forum Golf MK2 - 1984 - 1992
    Last Post: 05-04-2010, 11:17 PM
  4. w reg 1.8 20v strange idle
    By 10mmring in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2010, 08:29 PM
  5. Golf 1.8 AAM - strange idle
    By hefinland in forum Golf MK3 - 1993 - 1999
    Last Post: 13-11-2009, 12:41 PM
