Thread: P0171 code
  1. P0171 code
    Sep 2022
    Kent
    Hey everyone,
    I have recently bought a 2005 A4 B7 2.0 tfsi quattro, BGB engine if it makes any difference, 85,000 miles on it and keep getting a P0171 code.
    The code first came up about 100 miles after i bought it. After a rigorous search through many forums for some guidance i searched for vacuum leaks but couldn't find any, so changed the PCV Valve (non OEM) and attched hoses, erased the code and carried on.
    The code came up again after about 30 miles of driving. This time it developed a misfire which was quickly rectified with a new coil pack. I also removed the MAF and cleaned it. I again removed the code and this time the idle speed came down from around 800 to about 750 (which i've read is correct). The car seemed better but again after around 30 miles the code re-appeared.
    I searched again for Vacuum leaks and by luck found that the check valve coming off the brake booster had an open hose prong. I bunged this and removed the code again.
    The brakes instantly felt better (no suprise really) and the car feels a lot more responsive and boosts a lot better than before. Even the wife has commented on how different it feels.
    But again the code has come back. I know it could be any 1 of a few different things but i need it sorted and haven't really got the time to put in the garage. I'm fairly good with spanners so i can any jobs myself.
    I have taken a freeze frame of when the code last appeared with a half decent obd machine.
    Any help would be appriciated
    Many thanks
    Keith
  2. Re: P0171 code
    2018 Post(s)
    16555 (P0171)000369 - Fuel Trim; Bank 1: System Too Lean
    The easiest way is a charge air system pressure test or smoke test but you need the gear. Try removing the oil filler cap with the engine running to see if it is being heavily sucked down as I have come across a lot of faulty aftermarket PCV valves so we prefer fitting a genuine 06F 129 101 R which are often held in stock at the dealers and TPS, they cost £51.54. Does you code read have live data output? Having said that, the Febi repair kit 107189 is good value at around £90 as the hoses are often cracked.
  1. P0171 code - Looking for leaks help :) Engine Pics
    By sergioiacobucci in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-06-2015, 01:37 PM
  2. Polo 1.0 MY2000 P0171 code
    By Luxobarge in forum Polo - Derby - Lupo - Fox
    Last Post: 05-01-2014, 11:45 AM
  3. Fault Code P0171 Passat 1.8T Help Appreciated
    By Entropy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-07-2010, 03:23 PM
  4. audi a4, code p0171
    By muffin in forum Audi A4 - Archive Topics
    Last Post: 11-11-2006, 11:01 PM
  5. audi a4, code p0171
    By muffin in forum Archive posts
    Last Post: 11-10-2006, 08:38 PM
