Thread: Leon OBD fault occurring at 16.8 v
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
  1. Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Hi all
    I am getting a fault occurring and glow plug light flashing saying intermittent fuel pressure low.
    When I look at the freeze frame of the fault occurring I notice that the voltage at the time at terminal 30 is 16.8 Volts.
    This surely cant be right.
    Could this high voltage play havoc with the OBD sensors, etc?
    If so what could be allowing this high voltage?
    many thanks for looking
    Nigel
    2010 Leon II 1.6 cdi ecomotive. CAYC engine2022_09_22_from waynes diagnostic_01.jpg
  2. Re: Leon OBD fault occurring at 16.8 v
    2002 Post(s)
    If it really is hitting nearly 17v a number of the controllers will shut down, do a full vehicle scan and post the result.
  3. Re: Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Thanks for that Crasher.
    I cant get access to the diagnostic until next week so the full scan will have to wait.
    What do you mean by IF it is really hitting17v?
    For now lets say it is, what could cause it?
    many thanks
  4. Re: Leon OBD fault occurring at 16.8 v
    2002 Post(s)
    IF meaning it may not be but probably is so that would point straight to the alternator.
  5. Re: Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Ahh interesting. OK, thanks
    Do you think that if the voltage is 17v (in fact when we scanned it last time the voltage on fault occurrence was 17.8v) and the sensors are shutting down it would throw a code and send the car into limp mode?
    Many thanks
  6. Re: Leon OBD fault occurring at 16.8 v
    2002 Post(s)
    When I am using ODIS the dealer system, the car has to be on charge, you have to keep an eye on the permanently displayed "line 30" voltage as if it creeps up to 15v or above, many controllers shut down and store a "function limitation due to overvoltage" code so yes, 17.8v could really **** of a controller.
  7. Re: Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Ok thanks again. So I had better start searching for an alternator!! I know they are not cheap, the car has stop start.
    I post on how it went.
    thanks again for your help
  8. Re: Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Quick question if you dont mind. How important is it that I fit a stop start alternator? They seem to be the same amperage.
    Would it damage anything if I fitted a normal one?
    cheers
  9. Re: Leon OBD fault occurring at 16.8 v
    2002 Post(s)
    I don't know, we only fit the exact correct parts and the SS system is VERY fussy, what is the VIN?
  10. Re: Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    VSSZZZ1PZBR035141
    cheers
  1. leon po19300 fault code
    By hook in forum Leon
    Last Post: 05-02-2021, 02:27 PM
  2. Replies: 13
    Last Post: 11-08-2016, 09:18 PM
  3. Seat Leon 1.8 20v fault code
    By Batunball in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-12-2012, 11:31 PM
  4. Leon 1.6 cluster fault
    By badade 1.8t in forum Leon
    Last Post: 06-07-2012, 06:44 PM
  5. engine fault on a seat leon
    By merc2001 in forum Leon
    Last Post: 25-02-2010, 11:32 PM
