Thread: Leon OBD fault occurring at 16.8 v
Results 1 to 10 of 61
  1. Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Hi all
    I am getting a fault occurring and glow plug light flashing saying intermittent fuel pressure low.
    When I look at the freeze frame of the fault occurring I notice that the voltage at the time at terminal 30 is 16.8 Volts.
    This surely cant be right.
    Could this high voltage play havoc with the OBD sensors, etc?
    If so what could be allowing this high voltage?
    many thanks for looking
    Nigel
    2010 Leon II 1.6 cdi ecomotive. CAYC engine2022_09_22_from waynes diagnostic_01.jpg
  2. Re: Leon OBD fault occurring at 16.8 v
    2009 Post(s)
    If it really is hitting nearly 17v a number of the controllers will shut down, do a full vehicle scan and post the result.
  3. Re: Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Thanks for that Crasher.
    I cant get access to the diagnostic until next week so the full scan will have to wait.
    What do you mean by IF it is really hitting17v?
    For now lets say it is, what could cause it?
    many thanks
  4. Re: Leon OBD fault occurring at 16.8 v
    2009 Post(s)
    IF meaning it may not be but probably is so that would point straight to the alternator.
  5. Re: Leon OBD fault occurring at 16.8 v
    Jul 2020
    Silfiac - France
    Ahh interesting. OK, thanks
    Do you think that if the voltage is 17v (in fact when we scanned it last time the voltage on fault occurrence was 17.8v) and the sensors are shutting down it would throw a code and send the car into limp mode?
    Many thanks
  6. Re: Leon OBD fault occurring at 16.8 v
    2009 Post(s)
    When I am using ODIS the dealer system, the car has to be on charge, you have to keep an eye on the permanently displayed "line 30" voltage as if it creeps up to 15v or above, many controllers shut down and store a "function limitation due to overvoltage" code so yes, 17.8v could really **** of a controller.
  7. Re: Leon OBD fault occurring at 16.8 v
    Mar 2023
    Yorkshire
    Did you get to the bottom of it?
    Check the fuse for the engine ECU main live feed. Don’t check it with a test light/multimeter, physically pull the fuse and visually check it. It will most likely be a 30amp fuse in the engine bay fuse box. It won’t be blown but it will have previously blown and the metal strip in the fuse will have fused back together causing the voltage to the ECU to increase somehow. The voltage on the rest of the car will be fine, just the engine ECU voltage increases.
    Come across this a couple of times. First time it was a wiring issue causing the fuse to go and the other, just replaced the fuse and never faulted again.
  8. Re: Leon OBD fault occurring at 16.8 v
    Jan 2014
    France
    Hi, thanks for your message.
    I still have not got to the bottom of it and will certainly give your suggestion a shot. I will let you know how it goes.
    many thanks
  9. Re: Leon OBD fault occurring at 16.8 v
    Jan 2014
    France
    Hi, sooo, I looked at all the fuses couldnt see any problems but, when I tried starting her she went and runs perfectly. Maybe I disturbed something??!! It has done this before and run without problems for some time and then the fault re-occurs.
    But for the moment I will drive her locally and see how she goes.
    Thankyou very much for your input, I really appreciate you taking the time.
    I will keep everyone updated on how she goes.
    cheers
    Nigel
  10. Re: Leon OBD fault occurring at 16.8 v
    Jan 2014
    France
    Ok update for you all.
    She is running perfectly now so fingers crossed.
    So I got a battery control module from ebay and fitted it. The max voltage at terminal 30 is now 14.9V and all seems well.
    Thank you all for your input and if anything changes I will update you
    Thanks again
  1. leon po19300 fault code
    By hook in forum Leon
    Last Post: 05-02-2021, 02:27 PM
  2. Replies: 13
    Last Post: 11-08-2016, 09:18 PM
  3. Seat Leon 1.8 20v fault code
    By Batunball in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-12-2012, 11:31 PM
  4. Leon 1.6 cluster fault
    By badade 1.8t in forum Leon
    Last Post: 06-07-2012, 06:44 PM
  5. engine fault on a seat leon
    By merc2001 in forum Leon
    Last Post: 25-02-2010, 11:32 PM
