Thread: Leon OBD fault occurring at 16.8 v
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 61
  1. Re: Leon OBD fault occurring at 16.8 v
    #41
    Jul 2020
    Silfiac - France
    OK thanks, is there any way that the alternator can be tested?
    cheers
  2. Re: Leon OBD fault occurring at 16.8 v
    #42
    134 Post(s)
    2007 Post(s)
    Well I think you are doing. Remind me, did you replace the battery monitoring unit 1K0 915 181 H?
  3. Re: Leon OBD fault occurring at 16.8 v
    #43
    Jul 2020
    Silfiac - France
    Hi, no I unplugged it as you said but it made no difference. Do you think it might be worth trying a replacement?
    Nigel
  4. Re: Leon OBD fault occurring at 16.8 v
    #44
    134 Post(s)
    2007 Post(s)
    Possibly, they are silly money but the supplies have been erratic. The way it works is the BMU controls the alternator bu LIN BUS and according to a Self Study Program I read, if the BCM or the wiring to the alternator fails, the alternator is supposed to default to, I think, 13.5v.
  5. Re: Leon OBD fault occurring at 16.8 v
    #45
    Jul 2020
    Silfiac - France
    OK so if that BMU had failed it would have defaulted to 13.5v. That correct?
    cheers
    Nigel
  6. Re: Leon OBD fault occurring at 16.8 v
    #46
    134 Post(s)
    2007 Post(s)
    That is what I read a few months ago but I can't find the SSP, it was for a T6 where the LIN wire had broken (a common fault) and the SSP said if it lost LIN comms the alternator would default to, I think, 13.5v. I have a Self Study Program for the CAYC engine which goes into a little detail about the LIN alternator but does not mention the default voltage but it wouldn't be 18v! I have triple checked the alternator you have fitted and according to ETKA and then Tec-Doc using the genuine number it is correct.
  7. Re: Leon OBD fault occurring at 16.8 v
    #47
    Jul 2020
    Silfiac - France
    Ok thanks, so what would you do next? I am stuck stuck!!!
    cheers
    Nigel
  8. Re: Leon OBD fault occurring at 16.8 v
    #48
    134 Post(s)
    2007 Post(s)
    I would be taking a deep breath, ordering another alternator and praying I was right but really I can't think of anything else; the voltage stabiliser still bugs me.
  9. Re: Leon OBD fault occurring at 16.8 v
    #49
    Jul 2020
    Silfiac - France
    OK, whats bugging you about the stabilizer? Because its bugging me too, the clue is in the name for me, it should stabilize the voltage and thats exactly what I need.
    Nigel
  10. Re: Leon OBD fault occurring at 16.8 v
    #50
    134 Post(s)
    2007 Post(s)
    I only have the SSP for the Golf where the stabiliser is mounted differently but looking at the wiring diagram unplugging it should not kill the car and what is does could generate too much voltage. I was going to log into erWin Seat for an hour and find the SSP and study the diagrams on there but the erWin system is down... ohh, no its back up. I will be back in an hour or so... no, it's still broken.
  1. leon po19300 fault code
    By hook in forum Leon
    Last Post: 05-02-2021, 02:27 PM
  2. Replies: 13
    Last Post: 11-08-2016, 09:18 PM
  3. Seat Leon 1.8 20v fault code
    By Batunball in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-12-2012, 11:31 PM
  4. Leon 1.6 cluster fault
    By badade 1.8t in forum Leon
    Last Post: 06-07-2012, 06:44 PM
  5. engine fault on a seat leon
    By merc2001 in forum Leon
    Last Post: 25-02-2010, 11:32 PM
