Thread: Belt rubbing noise from cold?
  1. Belt rubbing noise from cold?
    Mar 2021
    Ripon
    7 Post(s)
    Recently, I changed the oil and engine filter on my 39000 mile 2018 2.0 TDI 150 CRLB and noticed when I started the engine from cold with the bonnet up a rubbing/whining noise coming from either the auxiliary or timing belt area.
    After 5 minutes or so when the engine warms up the sound goes away and the engine sounds normal. Otherwise the car runs fine with good power and fuel economy. Unless a window is down, I don't even notice the noise, so it's obviously been like this for a while
    Is this something I should be worried about? Any ideas what it might be? I hadn't planned on getting the timing belt changed for a few years yet.
  2. Re: Belt rubbing noise from cold?
    133 Post(s)
    1987 Post(s)
    I would replace the poly V belt AND whilst it is off, run the engine from cold to see if the noise is there. There seems to be a lot of cars suffering huge engine damage due to the poly V shedding a grove which gets drawn into the cam belt and causes havoc. We pushed a 2014 A1 2L TDI out onto the road last week ready to go for scrap because of this.
  3. Re: Belt rubbing noise from cold?
    Mar 2021
    Ripon
    7 Post(s)
    Quote Originally Posted by Mittens247 View Post
    Thanks @Crasher that sounds like a good idea. Cam belt seems completely enclosed in plastic covers presumably to protect against the scenario you describe?
  4. Re: Belt rubbing noise from cold?
    133 Post(s)
    1987 Post(s)
    Unfortunately a rib of belt can easily get drawn in behind the balancer pulley. The cover has been redesigned to try and stop it but it still happens so I am neurotic about poly v belts, plus many other things! The one we had here I think was put back on after a cam belt chnage as ironically looked very new and genuine. If you reuse a poly V you must mark its DOR or it can fall apart but for us, if it comes off, it goes in the bin.
  5. Re: Belt rubbing noise from cold?
    Mar 2021
    Ripon
    7 Post(s)
    Do you have any preferences over brands? Gates, Conti, Dayco or other?
  6. Re: Belt rubbing noise from cold?
    133 Post(s)
    1987 Post(s)
    All three are OE and great
  7. Re: Belt rubbing noise from cold?
    Mar 2021
    Ripon
    7 Post(s)
    Belt bought and guess what the noise has stopped! Guess I will change it anyway!
  1. Question Continuous rubbing noise
    By Jules88 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-06-2019, 08:05 AM
  2. Rubbing noise when turning right
    By Chriseybaby in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-09-2015, 08:31 AM
  3. Question Creaking/rubbing noise from front o/s
    By albion80 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-03-2012, 11:31 PM
  4. mk3 rubbing noise
    By Golf tdi Hal in forum Golf MK3 - 1993 - 1999
    Last Post: 07-05-2010, 07:03 PM
  5. rubbing noise n/s front
    By sweeper in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-07-2008, 10:09 PM
