Thread: 2.0L TFSI B9 Misfire / Judder
  1. 2.0L TFSI B9 Misfire / Judder
    Dec 2008
    I have a 67 plate auto Petrol A5 (B9) which was Misfueled with diesel a yeah ago, and driven.
    The car was ok at the time after having had the spark plugs changed, and ran fine for approx 12 months
    It recently came up with the ECU light and when plugged In threw a throttle body valve stuck error. This was cleared and then almost immediately it started misfiring / juddering under engine load - around 1k-2k revs especially when pulling away and in gear 4-5.
    Garage have said that no fault codes are currently showing - my question is where tk go next.. they’re reluctant to do any work without fault codes being thrown. I’m thinking it just be throttle body? Or perhaps spark plugs? Or anything else to check?
  2. Re: 2.0L TFSI B9 Misfire / Judder
    Aug 2015
    Cambridgeshire
    Seems like the throttle body is a good place to start. What was the actual code?
    If you know someone with VCDS you might be able to read the position, or try to do an alignment (search VCDS TBA)
    Reluctant to work on a car without a code they have recently cleared sounds a little backwards to me. I'd look for another garage too.
  3. Re: 2.0L TFSI B9 Misfire / Judder
    Dec 2008
    Thanks, not a bad idea!
    I thought it odd not to do anything without a fault code. They eventually took it on a road test, fairly reluctantly I must say. And we’re unsure what could be causing it and not especially bothered about it either.
    I’m supposed to be driving it to Italy and back (to Bristol UK) in two weeks so want to make sure it’s working!
  1. Audi A3 1.9 TDi ESP light and judder / misfire
    By harveys in forum New Member Introductions
    Last Post: 30-01-2020, 07:39 PM
  2. 2.0 tdi bmn / bkd engine idle misfire/judder PLEASE HELP!!!
    By GTRUSS in forum Golf MK5 - 2004 - 2009
    Last Post: 09-09-2012, 04:34 PM
  3. HELP!! Misfire/Judder AUY engine
    By perky85 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-07-2012, 10:11 PM
  4. Engine seems to misfire or judder
    By swankey in forum 2.0TDi - Engine
    Last Post: 12-06-2011, 12:53 PM
  5. Golf Mk4 2.0 Gti judder / misfire? - help!
    By ian davies in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2008, 05:45 PM
