Thread: can VCDS diagnose a blown turbo
Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 100
  1. Re: can VCDS diagnose a blown turbo
    #41
    2007 Post(s)
    Take the vacuum source 3.2mm hose off the vacuum servo pump pipe and apply a continuous vacuum to it.
  2. Re: can VCDS diagnose a blown turbo
    #42
    Dec 2011
    Swindon
    9 Post(s)
    i dont have a vac pump tool. also where is this located in the engine bay?
  3. Re: can VCDS diagnose a blown turbo
    #43
    Jul 2008
    Lisburn
    16 Post(s)
    replied to quick
    Stewart
    1986 coupe quattro (kv)
  4. Re: can VCDS diagnose a blown turbo
    #44
    2007 Post(s)
    Quote Originally Posted by geoff eeles View Post
    Suck man Suck! It is on the pipe from the vacuum pump to the servo.
  5. Re: can VCDS diagnose a blown turbo
    #45
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    If you happen to have a large syringe then it will do to test the basic ability of the rubber pipe and actuator diaphragm to hold a vacuum.
    I assume you have a code reader but not engine data logger like VCDS? The error suggests that the charge pressure system is not responding to requests for more air, which you'd be able to see if you could log the data. Cause could be turbo not generating pressure, pressure being lost in pipework or duff sensors.
  6. Re: can VCDS diagnose a blown turbo
    #46
    Dec 2011
    Swindon
    9 Post(s)
    i have VCDS 11.11 and tried to search for the boost logger, i saw n a youtibe video it was measuring block 115 but it must have been a dfferent version. Looking in the engine bay i have just noticed a lose wire from a terminal. not sure if it is relevant. i will try sucking a little later on
  7. Re: can VCDS diagnose a blown turbo
    #47
    2007 Post(s)
    Block 011
  8. Re: can VCDS diagnose a blown turbo
    #48
    Dec 2011
    Swindon
    9 Post(s)
    i had a mechanic look at it today and he found no boost leaks and no faulty sensors. looks like im removing the turbo to see if it has sticky viens
  9. Re: can VCDS diagnose a blown turbo
    #49
    2007 Post(s)
    SUCK ON THE VACUUM SYSTEM FEED PIPE!!! P0299 hardly ever comes from a sticking VNT system
  10. Re: can VCDS diagnose a blown turbo
    #50
    Dec 2011
    Swindon
    9 Post(s)
    well i sucked and all seemed ok. Today I removed the turbo and the spindle was sticking, it would only turn if i forced it and there is a scraping noise coming from the exhaust size. SO a replacement turbo it is.
    Is the spindle prone to seizing/sticking?
  1. How To Video: Cycling the N75 valve to diagnose turbo issues
    By eben80 in forum General
    Last Post: 17-11-2015, 09:54 PM
  2. Help me diagnose if any concerns in VCDS log
    By Rudidudi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-06-2015, 10:58 PM
  3. Passat 2006 - diagnose parking sensors with VCDS
    By xxxlogger in forum VCDS - Help Requests
    Last Post: 10-02-2014, 01:43 PM
  4. Replies: 1
    Last Post: 14-11-2013, 09:25 PM
  5. Can VCDS diagnose a power drain
    By turpal in forum VCDS - General Questions
    Last Post: 08-09-2013, 07:41 PM
