Thread: can VCDS diagnose a blown turbo
Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 100
  1. Re: can VCDS diagnose a blown turbo
    #51
    134 Post(s)
    2005 Post(s)
    That can be caused by the turbo overspeeding due to a sticky VNT system or by poor/loss of lubrication, if you have the turbo rebuilt (Midland Turbo are brilliant) they will be able to tell you what has happened as if it is lubrication failure, you need to know why before fitting a new/rebuilt unit.
  2. Re: can VCDS diagnose a blown turbo
    #52
    Dec 2011
    Swindon
    9 Post(s)
    i took it apart to see if i could solve it. the exhaust side was all caked in soot and i think it built up on the barings as i need to use force to rotate it and it is making a scraping noise. I was gonna get an exchange unit from Midland Turbos as i need the car back on the road asap as its been off since 10th august
  3. Re: can VCDS diagnose a blown turbo
    #53
    134 Post(s)
    2005 Post(s)
    They could probably turn yours around in three days but it’s easy for me as I can drop off there at 8am and pick up at 8am with a quick diversion on the way to work.
  4. Re: can VCDS diagnose a blown turbo
    #54
    Dec 2011
    Swindon
    9 Post(s)
    living in swindon my only option is next day delivery on an exchange and send mine to them with in their 14 days period
  5. Re: can VCDS diagnose a blown turbo
    #55
    Dec 2011
    Swindon
    9 Post(s)
    Crasher. as you use Midland Turbos alot, do they/can they supply gaskets for it as well?
  6. Re: can VCDS diagnose a blown turbo
    #56
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    When OEM Garrett was problematic on our BKD engine I got a Mellet one from Darkside that was a straight swap and somewhat cheaper than new Garrett. It cost a bit more than a Midland Turbo rebuild / exchange of the original, but helped with tight timelines.
    If you are sending it off make sure you know what bits to keep for fitting an alternate, or that might not come back with the original. That might include studs screwed into the casting (use the two-nut trick to get them out with no damage), oil connectors, etc.
  7. Re: can VCDS diagnose a blown turbo
    #57
    Dec 2011
    Swindon
    9 Post(s)
    Are Mellet ones decent turbos? i have had a look on DD website and it comes with the gaskets studs nuts and oil syringe.
  8. Re: can VCDS diagnose a blown turbo
    #58
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    It was a little while ago that I did mine. I'm pretty particular at getting parts that will last and not cause their own problem, so all i can say is I was suitably convinced at the time and had no trouble at all with fitting or use.
    I think the additional bits were Darkside rather than Mellet - bout could be doing them a dis-service. I wasn't impressed enough with their quality to use any / many of them, so reused the original parts where feasible.
  9. Re: can VCDS diagnose a blown turbo
    #59
    134 Post(s)
    2005 Post(s)
    Quote Originally Posted by geoff eeles View Post
    Yes they supply gaskets but not the almost always required downpipe clamp and the manifold to head nuts.
  10. Re: can VCDS diagnose a blown turbo
    #60
    Dec 2011
    Swindon
    9 Post(s)
    i spoke with Midlands this morning and they have taken my old turbo as they didnt have any outer casings, so it being repaired. they said they will provide all gaskets. the turbo to exhaust doesnt have a clamp, its just held on tp the DPF by 3 bolts
  1. How To Video: Cycling the N75 valve to diagnose turbo issues
    By eben80 in forum General
    Last Post: 17-11-2015, 09:54 PM
  2. Help me diagnose if any concerns in VCDS log
    By Rudidudi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-06-2015, 10:58 PM
  3. Passat 2006 - diagnose parking sensors with VCDS
    By xxxlogger in forum VCDS - Help Requests
    Last Post: 10-02-2014, 01:43 PM
  4. Replies: 1
    Last Post: 14-11-2013, 09:25 PM
  5. Can VCDS diagnose a power drain
    By turpal in forum VCDS - General Questions
    Last Post: 08-09-2013, 07:41 PM
