Thread: 3.0 BiTdi 320ps Boost pressure regulation
Results 1 to 10 of 11
  1. 3.0 BiTdi 320ps Boost pressure regulation
    Aug 2022
    Sofia
    Hello friends,
    since 1-2 months i have the following problem.
    When accelerating sometimes in the higher gears, sometimes in the lower it pops up in to limb mode and has power and turbos cut until car is shut down and started again.
    On the diagnostics it records the error :
    Turbo was removed and checked, no problems,
    everything connected or working with the turbo was checked and no problem,
    the exhaust and DPF was checked and removed, no problems.
    I am starting to hit a wall here. Please for any assistance.
  2. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Hi it says 4 faults found but you only show 1….
    What are the other 3 faults?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Aug 2022
    Sofia
    Quote Originally Posted by dean warren View Post
    Hello,
    only nox sensor bank 2, the others are not relevant to the issue.
    The repair shops idea is to replace the 2 temperature sensors who are registering the exhaust gasses.
    1 of them is showing +800 degrees values and 0.7 backpressure.
  4. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    You should be able to take it for a drive and log actual / requested boost during steady driving and with moderate to high acceleration on an uphill. If there are clear, consistent deviations then something is happening in the turbo, boost pipes or sensors.
  5. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Aug 2022
    Sofia
    Hello,
    car was driven and tested 5 days every day, there are no problems or faulty sensors, only exhaust gas sensors. One is showing -40 and the other +800 value and the backpressure is 0.7 bar which i understand is high. Nothing else is faulty, it has been tested and disassembled with no issues found. So my question is could it be possible to be these 2 temperature sensors?
  6. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Mar 2010
    Derry ireland
    66 Post(s)
    What is the engine code for your car. temp sensors can be easily be checked out either on or off the vehicle but i cannot see them being the problem
  7. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by Nomakbg View Post
    car was driven and tested 5 days every day, there are no problems or faulty sensors...
    What sort of testing does that mean? If it didn't cause the problem to occur the it is unlikely to help you fix it.
  8. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Aug 2022
    Sofia
    Quote Originally Posted by mickeybo View Post
    4G2FN is what you need? I am also bit curious about the temp sensors to be the issue, and do not want to change something is not the problem in general because those sensors are not cheap.
  9. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Aug 2022
    Sofia
    Quote Originally Posted by VAG-Abound View Post
    Mechanics were driving the car trying and replicating the problem, watching live data on all the cars components to see anything out of the usual or which may be the cause.
    Turbos were tested on a machine, vacuum was tested, the servo motor for the turbos was tested,all the turbo pipes and intake was checked, the exhaust and the DPF was also checked.
    All seemed good but the only faulty thing was the temp on one of the temp sensors, as mentioned the healthy one was showing values in the normal range -40 but the other was showing way higher temps.
    They say that after changing both sensors they can determine if the sensors are the fault or something else.
    Forgot to mention that it turns out turbos are okay but sometimes the car just cuts them off when she doesn't like something, problem is to find out what is reason.
  10. Re: 3.0 BiTdi 320ps Boost pressure regulation
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    If there is no consistent variation in requested vs actual boost pressure that might usually be within tolerance but just nip outside it sometimes including during sustained hard acceleration on an incline then it may be an electrical problem with those sensors. I'm not sure if the figure shown in your screenshot is a momentary actual, or averaged across time, so a brief zero from a broken wire would push down the average.
    Is there somewhere that you can pretty reliably make the problem happen? Unplugging some sensors will make it use a default value, which is sub-optimal but keeps the turbo active. If you can't make it go into limp when normally would with the sensor unplugged than it may be the cause.
  1. 1.6TDI P0299 Boost Pressure Regulation
    By dave_ph in forum Golf MK6 - 2009 - 2013
    Last Post: 11-11-2021, 09:48 PM
  2. Please Help Boost Pressure Regulation
    By Mischiu in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2016, 12:41 PM
  3. Replies: 1
    Last Post: 06-06-2014, 09:50 AM
  4. Boost Pressure Regulation
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-05-2009, 02:03 PM
  5. Boost pressure regulation!
    By s_line_junkie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-05-2009, 10:18 AM
