Thread: Steering Column Play
  1. Steering Column Play
    Oct 2015
    St Helens, England
    Hi everyone,
    I've got an issue with the telescopic extension on my steering column. I believe the end stop is broken (the white plastic item in the photo - the photo is 90 degrees left though that's not the orientation i took it in).
    In addition to that, if the column is unlocked, then the stalks and whole clock spring unit can rotate a few degrees either way (yt link below)
    I'm going to assume that this isn't an easy fix.
    Does anyone have any idea what's going on / what needs doing?
    Thanks.
    31 July 2022 - YouTube
  2. Re: Steering Column Play
    1837 Post(s)
    What is the VIN?
  3. Re: Steering Column Play
    Oct 2015
    St Helens, England
    Cheers Crasher. PMd.
  4. Re: Steering Column Play
    1837 Post(s)
    I can't find anything on the offline TPI list I have but it is a bit out of date. What an insane number of steering column units! 21 on that car alone according to age and spec. The column is only available as a complete assembly and the one used in your car, 4G0 419 502 S, changed part number 4G0 419 502 AB in December 2016 with your car having been built 28.07.2015, it retails at £1139.51
  5. Re: Steering Column Play
    Oct 2015
    St Helens, England
    Ooffttt. Thanks for looking into it Crasher.
    Given it seems it's just a cosmetic issue at the moment (no issues with driving) I can't justify the price tag associated with changing the whole unit.
    Next time it's in for a service, I'll see if they've come across anything like it.
    Thanks again.
  1. Question washer fluid leak on steering column - how to remove column shroud etc
    By flat4fanatic in forum Touran - Sharan - Caravelle
    Last Post: 29-03-2014, 11:28 PM
  2. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  3. Vibration through steering column
    By alang498 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2012, 10:54 PM
  4. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
  5. MK3 Steering Column Help
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2007, 06:46 PM
