Thread: Coupe quattro. 2.8 Clutch problem.
  1. Unhappy Coupe quattro. 2.8 Clutch problem.
    May 2022
    Rudkøbing, Denmark.
    The last two days I have had a strange experience with the gear change on my car. Normally it is a very smooth operation but suddenly it was a very different process. Very physical, awkward, mechanical and hard. The normal movement of the gear lever was difficult. However when the engine was warm it was normal. One other unusual detail, my foot had the clutch fully depressed. Could it be a servo problem?
    Thanks.
  2. Re: Coupe quattro. 2.8 Clutch problem.
    131 Post(s)
    1976 Post(s)
    The brake servo is not involved, what is the selection like with the engine not running?
  3. Re: Coupe quattro. 2.8 Clutch problem.
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Did he perhaps mean 'slave' rather than servo?
  4. Re: Coupe quattro. 2.8 Clutch problem.
    131 Post(s)
    1976 Post(s)
    Not allowed to use that term anymore, no idea what to replace it with though…
  5. Re: Coupe quattro. 2.8 Clutch problem.
    May 2022
    Rudkøbing, Denmark.
    Without the engine running the gearchange is perfect. I am going to the garage I use here in a couple of hours and see what they say. I got the impression the last time I drove it that as the engine got warmer the problem decreased. I am going to let the engine run for a few minutes before I go the garage and maybe there will be a difference. The other noticeable difference was that the clutch pedal was on the floor, I will try double declutching when I go the garage.
    Julian.
  6. Re: Coupe quattro. 2.8 Clutch problem.
    131 Post(s)
    1976 Post(s)
    The pedal stayed on the floor?
  7. Re: Coupe quattro. 2.8 Clutch problem.
    May 2022
    Rudkøbing, Denmark.
    Not when I drove to the garage but when the garage owner drove it he mentioned the pedal and it is unusual to have to floor it all the time. His assesment was that it needs a new clutch and taking the mileage into consideration 300,000km. it must be expected. So another unexpected financial bombshell to handle!
  1. Engine out of '91 200 20V Turbo Quattro into '90 Coupe Quattro
    By 90 Coupe Q in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-11-2009, 11:38 AM
  2. quattro coupe
    By mikejehu1971 in forum 80 - 90
    Last Post: 21-07-2009, 08:13 PM
  3. Audi 80 Coupe 2.0 8 valve - clutch replacement
    By Yellow Peril in forum 80 - 90
    Last Post: 24-02-2009, 07:37 PM
  4. Clutch for a Coupe 2.0e
    By deecoupe22 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 30-05-2008, 06:10 PM
  5. clutch problem a6 2.5 tdi quattro v6
    By james william in forum Chat - Anything with wheels
    Last Post: 25-10-2007, 02:44 PM
