Thread: BKD Touran losing coolant - where to?
  1. BKD Touran losing coolant - where to?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Our MY08 BKD engine Touran has started losing quite a bit of coolant regularly, but not all the time. On some short-ish (20 mile) trips the coolant light comes on, and the level is well below minimum. On others it doesn't.
    I built a little widget to pressure test the system. Turns out a 40mm plumbing waste compression fitting goes quite nicely on the expansion tank with the lid removed, and a 7/32" hole is perfect for screwing a long Presta valve from a donor cycle inner tube into. The part I had around happened to be a tee-joint, but only two connections are needed so a coupler would be fine.
    I can get the pressure up to ~1.5 Bar easily, and it holds for 20 minutes. Big "pop" if I pull it off rather than release pressure steadily.
    No sign of coolant around engine while doing this. Oil is a lovely, silky black. C-suffix cylinder head. Exhaust is generally clear with odd puffs of blackness when accelerating hard.
    Only clue is that sometimes when reversing off of drive a trail of water is left, as though it had gathered on plastic undertray and sloshed off as car moved. Now parking over a sheet of cardboard with tray removed, but no drips seen so far.
    I'm not aware of any valves that let water into parts of system sometimes, but make a water-tight isolation of it at others. I'm wondering if there could be a hairline fracture in something that opens up when car is doing some particular thing, but is pressure tight at others.
    Any pointers from anyone?
  2. Re: BKD Touran losing coolant - where to?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Further reading is suggesting hairline cracks in radiator. I'll see if I can see anything there.
  1. 55 1.9tdi 105 touran losing coolant, heaters not working and engine fan
    By rossyjr in forum Touran - Sharan - Caravelle
    Last Post: 22-02-2017, 09:57 PM
  2. A6 1.9 TDI losing coolant
    By Rudidudi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-12-2015, 01:52 PM
  3. Losing coolant
    By Cannondave in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2015, 09:39 AM
  4. touran losing coolant
    By angnlee in forum Touran - Sharan - Caravelle
    Last Post: 17-10-2013, 05:21 PM
  5. I'm losing coolant :(
    By njek in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-04-2010, 03:12 PM
