Thread: Cranking but won't start
Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
  1. Re: Cranking but won't start
    #41
    Jul 2022
    Strood
    Thanks that a great help It was a continuity test so will check for 12v tomorrow across all fuses and the gateway hopefully I will have some idea if power is getting to the gateway.
  2. Re: Cranking but won't start
    #42
    Jul 2022
    Strood
    At the minute fault codes are very limited as diagnostics is only working on kline so I'm trying to get the canbus up and running for a more in depth idea of what is going on
  3. Re: Cranking but won't start
    #43
    Jul 2022
    Strood
    Been a bit delayed in further testing with this heat bit just tested power to canbus module and only getting power through pin 14, nothing through pins 1 and 2, any idea if that runs through any fuses or is it a break in the wires?
  4. Re: Cranking but won't start
    #44
    Jul 2022
    Strood
    With a lack of communication to power control module could the issue be one of the relays in it not sending power to all the modules? Anyone have any wiring diagrams of the mk5 golf?
  5. Re: Cranking but won't start
    #45
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Quote Originally Posted by Gazza243 View Post
    Pins 1 and 2 do share a fuse, which should be 10A. Try SB24 - slot number 24 in the box to right as you look into engine. Or possibly SB12 if you have the "simpler" layout with only two relays.
    Check that each side of the fuse has ~12V. At least one side should - it's straight from the battery.
  6. Re: Cranking but won't start
    #46
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    With a lack of communication...
    Talking of lack of comms, how's it going? Working now?
  7. Re: Cranking but won't start
    #47
    Jul 2022
    Strood
    Sorry didn't see any new messages, haven't tried what you suggested yet but will update as soon as I've tried
  8. Re: Cranking but won't start
    #48
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    If it is the fuse then there is a reasonable chance that it will pop again, particularly when engine started. Hopefully you can get as far as a pre-start scan to see that everything is there. If it pops as soon as inserted then an immediate check could be continuity from "load" side of fuse (ie not the side connected to battery) to bodywork. If it is low Ohms then there may be rubbed through insulation between engine fuse and gateway.
  9. Re: Cranking but won't start
    #49
    Jul 2022
    Strood
    sorry for the delay in replying, with the school holidays etc not had no time to work on it.
    After running a new 12v feed to the gateway module ive managed to get a full scan so hoping im making progress in getting this running again with the help of you guys
    Monday,29,August,2022,16:10:25:42922
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
    VCDS Version: 22.3.1.4
    Data version: 20220407 DS337.0
    Ross-Tech: Home
    VIN: WVWZZZ1KZ4W067231 License Plate:
    Mileage: 180940km-112430mi Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W067231 Mileage: 180940km-112430miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Cannot be reached 1100
    Address 01: Engine Labels: 036-906-032-AXP.lbl
    Part No SW: 036 906 032 AG HW: xxxxxxxxxxx
    Component: BOSCH ME7.5.10 5612
    Revision: 00000000 Serial number: VWZ7Z0D9133483
    Coding: 0000071
    Shop #: WSC 01279 785 00200
    VCID: 55A401BBFCA6FC27CC-8000
    VINID: 9E69EAAAA05BA849C01870830400CB0A24
    No fault code found.
    Readiness: 1110 0101
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0019073
    VCID: 3A7EB20775F8335FC1-806E
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 CB
    Component: Climatic PQ35 060 0201
    Shop #: WSC 00000 000 00000
    VCID: 66C6367751C067BF55-8032
    1 Fault Found:
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
    Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
    Component: Bordnetz-SG 1.0 H30 0701
    Revision: 00030000 Serial number: 00000000424868
    Coding: 008D0F0600041800001400001400000000
    VCID: 3778AB3346EA2E373E-8062
    Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    3 Faults Found:
    01800 - Light Switch (E1)
    008 - Implausible Signal
    01064 - Terminal 58d; Interior Dimming
    012 - Electrical Fault in Circuit
    00987 - Lamp for Brake Light; Left (M9)
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 A HW: 1K0 909 605 A
    Component: 0M AIRBAG VW8 022 0500
    Revision: 04022000 Serial number: 0033FD077VZS
    Coding: 0012365
    Shop #: WSC 01268 785 00200
    VCID: 2A5E8247855883DFB1-807E
    Subsystem 1 - Serial number: 6332MSME17123001
    Subsystem 2 - Serial number: 6342MSME3D402E15
    Subsystem 3 - Serial number: 6351HSME53033C01
    Subsystem 4 - Serial number: 6361HSME010C3001
    1 Fault Found:
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    010 - Open or Short to Plus - MIL ON
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 HW: 1K0 953 549
    Component: Lenksäulenmodul 012 0030
    Coding: 0000002
    VCID: 6FE853537E3AA6F726-803A
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 950 P
    Component: KOMBIINSTRUMENT VDD 3554
    Coding: 0001401
    Shop #: WSC 00199 210 64534
    VCID: 3564A13B5CE6DC272C-8060
    Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 C HW: 1K0 907 951
    Component: Gateway H08 0080
    Revision: 08 Serial number: 2100103C200E11
    Coding: 3D0F0340070003
    VCID: 27587B73964ABEB7AE-8072
    3 Faults Found:
    01305 - Databus for Infotainment
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 180945 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:34:49
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 180945 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:34:53
    00470 - Company Comfort Databus in Single Wire
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 156
    Mileage: 180945 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:35:10
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO 3554
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0116
    Coding: 0000052
    VCID: 306A902FA384F90F7F-8064
    1 Fault Found:
    011 - Open Circuit
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V1.clb
    Part No: 1K2 909 144 E
    Component: EPS_ZFLS Kl.0 1202
    VCID: 2E568E57B9B0EFFF6D-807A
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - - - MIL ON
    Freeze Frame:
    Mileage: 920 km
    Count: 1
    Steering Angle: 0.00°
    Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 C
    Component: KSG 0201
    Coding: 00E802087F2D8404085B0100
    1 Fault Found:
    011 - Open Circuit
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Coding: 0000052
    VCID: 316C952BA88EF00770-8064
    1 Fault Found:
    011 - Open Circuit
    Address 56: Radio
    Cannot be reached
    End-------------------------(Elapsed Time: 01:22)--------------------------
    all help greatly appreciated and ill update any changes.
    thanks
  1. Please Help won't start (no cranking) 53 plate 1.9tdi
    By ianlovatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-12-2020, 07:33 PM
  2. 1996 1.8 T cranking time before start
    By FrenchAudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-02-2020, 08:09 AM
  3. Replies: 17
    Last Post: 01-03-2019, 02:56 PM
  4. Allroad 2.5 2005, drop in economy, flat performance, longer cranking on cold start
    By A. Waterfield in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-08-2015, 03:39 PM
  5. 2.0tdi cranking but won't start..
    By Messer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-12-2012, 10:13 PM
