Thread: Cranking but won't start
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
  1. Cranking but won't start
    Jul 2022
    Strood
    Hi all,
    Hopefully someone can help me with an issue I'm having with my 2005 vw golf 1.4 fsi.
    Drove it on school run and dropped kids off, when I came out it started but after a few seconds it died. Checked fuel pump and turns out it weren't working so put in another known working one but still won't start. Checked all fuses and all good, swapped relays fuel pump and horn to confirm relay still working and it was. Changed crankshaft sensor as had fault code and now code has gone but still won't start.
    Now I have no codes and no idea why it's not starting
    Thanks in advance for any help
  2. Re: Cranking but won't start
    Mar 2010
    Derry ireland
    63 Post(s)
    engine code posted up would be a good start
  3. Re: Cranking but won't start
    Jul 2022
    Strood
    Sorry engine code is bkg I believe
  4. Re: Cranking but won't start
    131 Post(s)
    1973 Post(s)
    If it is high mileage, the cam chain may have jumped.
  5. Re: Cranking but won't start
    Jul 2022
    Strood
    Hi crasher,
    Is there any way of checking without stripping it down?
  6. Re: Cranking but won't start
    Jul 2022
    Strood
    Mileage is 112000 so not as high as most but certainly possible as I have no service history for it so not sure if it was regularly serviced or not
  7. Re: Cranking but won't start
    131 Post(s)
    1973 Post(s)
    I have had many jump much earlier than 112K. You have to set the number 1 piston at TDC and see if the cam plate will go in.
  8. Re: Cranking but won't start
    Jul 2022
    Strood
    Cheers I will get it checked, is there anything else you could think of that it may be if not that? Read a lot of forums recently and been seeing other issues like fuse box, coolant temp sensor, ecu
  9. Re: Cranking but won't start
    131 Post(s)
    1973 Post(s)
    IF there are definitely no codes and you can read live data such as RPM, coolant temp etc then you are down to basics, fuel, spark, timing and compression.
  10. Re: Cranking but won't start
    Mar 2010
    Derry ireland
    63 Post(s)
    The main engine control relay fires up fuses f11b fuse 12b fuse f6b fuse 7b fuse f8b & up stream fuse 26 b These fuses are fed via main engine control relay has to be your first checks can you check & get back
  1. Please Help won't start (no cranking) 53 plate 1.9tdi
    By ianlovatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-12-2020, 07:33 PM
  2. 1996 1.8 T cranking time before start
    By FrenchAudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-02-2020, 08:09 AM
  3. Replies: 17
    Last Post: 01-03-2019, 02:56 PM
  4. Allroad 2.5 2005, drop in economy, flat performance, longer cranking on cold start
    By A. Waterfield in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-02-2015, 08:40 PM
  5. 2.0tdi cranking but won't start..
    By Messer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-12-2012, 10:13 PM
