Thread: Gearbox Malfunction!
  1. Gearbox Malfunction!
    Near Blackpool
    48 Post(s)
    Occasionally i get a gearbox malfunction error and it scrolls from park to N on the dash and flashes, it seems to do this every 6 months or so and a quick clear on VCDS normally fixes it.
    Today it wouldn't clear, tried power cycling and clearing both faults from Engine ECU and Gearbox ECU and it came straight back.
    Preformed a calibration on the gear selector which failed because it asked me to move shifter to park and i couldn't because it locked its self due to the fault (power cycling unlocked it but VCDS cancelled due to safety reason)
    The fault then auto cleared?! It works normally again, so bizzare
    Tuesday,05,July,2022,12:44:54:30277
    VCDS Version Release 22.3.1 (x64) Running on Windows 10 x64(Parallels)
    Ross-Tech: Home
    Address 02: Auto Trans Labels: 0CJ-927-156.clb
    Control Module Part Number: 4G0 927 153 F HW: 0CK 927 156 Q
    Component and/or Version: 0CK 30TDI RdW H01 0004
    Software Coding: 100001
    Work Shop Code: WSC 02391 785 00200
    ASAM Dataset: EV_TCMDL382021 002014 (AU57)
    ROD: EV_TCMDL382021_AU49.rod
    VCID: 2C5D1609477D72EF43-8079
    1 Fault Found:
    20779 - Transmission Range Sensor 1/2
    P2805 00 [167] - Correlation Error
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Mileage: 174889 km
    Date: 2022.07.05
    Time: 12:40:58
    Engine RPM: 0 /min
    Driving position: Sensor malfunction
    ATF temperature: 18 °C
    Transmission output speed: 0 /min
    Voltage terminal 30: 12.3 V
    Engine torque: 0 Nm
    selected gear: N
    Ctrl. mod.: operating condition: Pre-run
    Auxiliary pump for transmission: requesting function: No function active
    Auxiliary hydraulic pump for transmission oil: current: 0 A
    Oil pressure reservoir: pressure: 0.0 bar
    Pressure of clutch 1: actual value: 0.0 bar
    Pressure of clutch 2: actual value: 0.0 bar
    Clutch status: New
    Unlearning counter according OBD: 40
    Occurrence_counter_over_length_of_life: 8
    Tuesday,05,July,2022,12:46:29:30277
    Ross-Tech: Home
    Address 01: Engine Labels: 059-907-401-V2.clb
    Control Module Part Number: 4G1 907 401 HW: 4G0 907 401 E
    Component and/or Version: 3.0TDI EDC17 H14 0005
    Software Coding: 1A254012042401030800
    Work Shop Code: WSC 15022 002 1048576
    ASAM Dataset: EV_ECM30TDI0114G1907401 001006 (AU57)
    ROD: EV_ECM30TDI0114G1907401.rod
    VCID: 61C3B73D703FEF87A0-8035
    1 Fault Found:
    8172 - Selector Lever
    P0919 00 [039] - Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 174889 km
    Date: 2022.07.05
    Time: 12:45:47
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 16 °C
    Intake air temperature: 21 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 11.340 V
    Engine status: COENG_READY
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
    Readiness: 0 0 0 0 1
  2. Re: Gearbox Malfunction!
    1840 Post(s)
    This is on an A7, what is the VIN?
  3. Re: Gearbox Malfunction!
    Near Blackpool
    48 Post(s)
    I’ve pm’d it you mate
  4. Re: Gearbox Malfunction!
    1840 Post(s)
    It had the, and I quote, "gearbox oil" changed on 2016-04-29 at 36920 miles then on 2017-10-09 at 70113 miles so how many miles now? It is odd though as by that deception the ATF has not been changed and this is due every 40k so is that a misprint or true? I can't see that it has had the software update 37J8 which MAY be relevant, digging deeper it looks like you may need to fit the revised gear selector unit 0CK 325 110 Q. Personally I would get it on ODIS with Guided Fault finding to find out more information on those two fault codes.
  5. Re: Gearbox Malfunction!
    Near Blackpool
    48 Post(s)
    Yeah it’s due it’s gearbox oil change and is booked in to have it done. Will ask them whilst it’s in if they can update its software.
  6. Re: Gearbox Malfunction!
    Near Blackpool
    48 Post(s)
    Just dropped it off, They’ve also told me it has a recall for emissions? I asked what it was, he said it’s either a software update or it’s something to do with the EGR and he’d find out and let me know.
  7. Re: Gearbox Malfunction!
    Near Blackpool
    48 Post(s)
    Turns out it has a lamba sensor recall which they are ordering and will re-book.
    Looking at the invoice it has 2 drain plugs and the oil, no filter quoted? Surely they changed a filter?
    Also weirdly they spilt adblu all down the side of the car, I asked why they even touched the adblu and they said “not sure, maybe it was part of the recall checks”
    Another quality visit to Preston audi
  1. Gearbox Malfunction error showing up sporadically
    By DunkedOn in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-09-2023, 06:39 PM
  2. gearbox malfunction a6 c7 allroad 2012
    By chris.d in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 06-06-2021, 09:28 PM
  3. Gearbox malfunction
    By Dazlav@aol.com in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 13-04-2021, 01:46 PM
  4. Question Gearbox Malfunction
    By JayNana in forum A7 - S7
    Last Post: 23-03-2017, 04:58 PM
  5. Replies: 2
    Last Post: 12-08-2016, 07:35 PM
