Thread: Help needed
  1. Help needed
    Jun 2021
    uk
    Any help would be appreciated thanks!
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56 61 62
    69 72
    VIN: WVWZZZ7N Mileage: 90690km-56352miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 HH HW: 03L 907 309 Q
    Component: R4 2.0l TDI H28 9980
    Revision: 44H28--- Serial number: CVN: 9078505338D3FF82
    Coding: 0019001A040501080000
    Shop #: WSC 00706 210 00000
    ASAM Dataset: EV_ECM20TDI01103L906018HH 003015
    ROD: EV_ECM20TDI01103L906018H_VW36.rod
    VCID: 77ABEAC3FF4B3E33FE5-8022
    VINID: 9E69EAAAA1DEA959800442060005758148
    2 Faults Found:
    4807 - EGR System
    P0401 00 [096] - Insufficient Flow
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4891 - EGR Valve (N18)
    P0403 00 [237] - Malfunction
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 8
    Mileage: 90615 km
    Date: 2022.06.24
    Time: 18:07:21
    Engine RPM: 1839.50 /min
    Normed load value: 63.5 %
    Vehicle speed: 64 km/h
    Coolant temperature: 83 °C
    Intake air temperature: 24 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 13.160 V
    Unlearning counter according OBD: 40
    Air mass: actual value (mg/stroke): 774.1 mg/stroke
    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
    EGR Solen.val.: actual value: 94.63 %
    EGR valve: offset closed: 1.89 %
    Actuator for high pressure EGR: status-Bits 0-7: 55
    Actuator for high pressure EGR: status-Bits 0-7: 0
    Actuator for high pressure EGR: status-Bits 0-7: 3
    Actuator for high pressure EGR: status-Bits 0-7: 4
    High press EGR actuator: actual unconditioned volt val: 1104.4 mV
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes Labels: 7N0-614-109.clb
    Part No SW: 7N0 614 109 P HW: 7N0 614 109 P
    Component: J104 C3 450M VD96 0030
    Revision: --H07--- Serial number: 00000007425456
    Coding: 0019991
    Shop #: WSC 00020 790 00000
    VCID: 3A2D33F78059E35BC1B-806E
    1 Fault Found:
    02214 - Tire Pressure Warning
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 6
    Fault Frequency: 145
    Reset counter: 184
    Mileage: 81360 km
    Time Indication: 0
    Date: 2016.04.15
    Time: 09:29:09
    Freeze Frame:
    Speed: 90.0 km/h
    Hex Value: 0x0000
    Bin. Bits: 00000000 00000000
    Voltage: 14.75 V
    Bin. Bits: 00011111
    Count: 185
    Hex Value: 0x0000
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 7N0 907 044 K HW: 7N0 907 044 K
    Component: Clima-Sharan H01 0303
    Revision: 00001K01
    Coding: 021000C449
    Shop #: WSC 00020 999 00000
    ASAM Dataset: EV_ClimatronicSharan A01005
    ROD: EV_ClimaAutoSharaBasis.rod
    VCID: 382929FFB2D5F14B37F-806C
    1 Fault Found:
    9481200 - Refrigerant Pressure
    B10AB F0 [009] - Too Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 56
    Mileage: 74477 km
    Date: 2021.08.04
    Time: 12:16:06
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 5K0 937 084 K HW: 5K0 937 084 K
    Component: BCM PQ35 B 122 0173
    Revision: BA122001
    Coding: 40180A3B8125F1C0408000C01000006443811308424D292264 80872000C1
    VCID: 3A2D33F78C59E35BC1B-806E
    Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 130814 31 0032
    Serial number: 130821171527
    Coding: 004DBD
    Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
    Component: RLFS 024 0042
    Serial number: Y13M10D05H16M57S12S1
    Coding: 4208BB
    Subsystem 3 - Part No: 7N0 951 171 A
    Component: DWA-Sensor 00 002 0206
    Coding: 000000
    Subsystem 4 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    No fault code found.
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
    Component: VW10Airbag00M H12 0014
    Serial number: 003LGPLCTG8M
    Coding: 00304D
    ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
    ROD: EV_AirbaVW10TS6VW428.rod
    VCID: 3FDB42E397FBC673F65-806A
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: --- HW: ---
    Component: S.Sens.Fahr.V --- ---
    Serial number: 3493ETS609580C5189D.
    Coding: 000000
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 2 - Part No SW: --- HW: ---
    Component: S.Sens.Beif.V --- ---
    Serial number: 3503ETS60BF05BD189D2
    Coding: 000000
    Rear Side Airbag Crash Sensor (on driver's side):
    Subsystem 3 - Part No SW: --- HW: ---
    Component: S.Sens.Fahr.H --- ---
    Serial number: 3513ETS60199DC518DD1
    Coding: 000000
    Passenger side rear thorax airbag crash sensor:
    Subsystem 4 - Part No SW: --- HW: ---
    Component: S.Sens.Beif.H --- ---
    Serial number: 3523ETS6030E19B189DU
    Coding: 000000
    Crash sensor for front airbag: driver side:
    Subsystem 5 - Part No SW: --- HW: ---
    Component: F.Sens.Fahr --- ---
    Serial number: 35540TS609317C518DDN
    Coding: 000000
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 521 BJ HW: 5K0 953 569 C
    Component: LENKS.MODUL 016 0140
    Revision: FF010042 Serial number: 20130927100342
    Coding: 5080040000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 75B7E0CBE5474C23EC9-8020
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 7N0 920 960 J HW: 7N0 920 960 J
    Component: KOMBI H04 0809
    Serial number: 00000000000000
    Coding: 440F01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
    VCID: 392F2CFB89DFE843C81-806C
    Address 18: Aux. Heat Labels: 1K0-815-071.clb
    Part No: 7N0 963 271 E
    Component: Zuheizer 051 2940
    Revision: 00051000 Serial number: 09024297000000
    Coding: 0000041
    VCID: 363527C7B441073B253-8062
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 AL HW: 7N0 907 530 AL
    Component: J533 Gateway H58 1642
    Revision: H58 Serial number: 021013F1001572
    Coding: 468003
    VCID: 7AADF3F7CCD9235B81B-802E
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0809
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    VCID: 6A8DC3B7BCF993DB71B-803E
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
    Component: SG EXT.PLAYER H19 0770
    Revision: A1001003 Serial number: 7665347262
    Coding: 010100
    VCID: 2B0306B373034AD34AD-807E
    Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
    Part No SW: 7N0 959 793 F HW: 7N0 959 793 F
    Component: TSG FA H03 0553
    Revision: Serial number: 0000072171072
    Coding: 011006208001411011
    VCID: 45D7500BF5A79CA3BC9-8010
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 7N0 909 144 R
    Component: EPS_ZFLS Kl. 272 3501
    Revision: 00H21000
    VCID: 42DD4B17E889AB9B99B-8016
    Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
    Part No SW: 7N0 959 792 F HW: 7N0 959 792 F
    Component: TSG BF H03 0553
    Revision: Serial number: 0000073358039
    Coding: 011004208001411011
    VCID: 44D14D0FFE9DA5ABAB7-8010
    Address 53: Parking Brake Labels: 3AA-907-801.clb
    Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
    Component: J540 EPB4 VW-86594 0010
    Revision: H19 Serial number: 00000001462601
    Coding: 0024167
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
    Component: Radio RCD310 004 0119
    Revision: 01000001 Serial number: VWZ1Z2N1894336
    Coding: 0100040004000D
    VCID: 353720CBA5470C232C9-8060
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
    Component: Batt.regelung H58 1642
    Coding: 030F7859
    VCID: 71BFD4DB91AF6003301-8024
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Serial number: 30276053041491180686
    Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
    Part No SW: 7N0 959 794 G HW: 7N0 959 794 G
    Component: TSG HL H04 0553
    Revision: Serial number: 0000075977357
    Coding: 010004200001411001
    VCID: 47CB5A03CFAB8EB34E5-8012
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: ConWysTrailer H07 0100
    Revision: 3A001001 Serial number: 00000132425721
    Coding: 0100000100000000
    Shop #: WSC 00007 223 174336
    VCID: 303911DF5A25290B7FF-8064
    Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
    Component: TSG HR H04 0553
    Revision: Serial number: 0000075983113
    End----(Elapsed Time: 01:34, VBatt start/end: 12.1V/12.1V. VIgn 11.9V)-----
  2. Re: Help needed
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Delete this if you can and stick with the post in the model section.
  1. Replies: 6
    Last Post: 06-07-2022, 10:52 AM
  2. Replies: 4
    Last Post: 07-01-2021, 08:42 PM
  3. Blank gear surround button needed - help needed please
    By simon_lenard in forum Passat CC
    Last Post: 24-10-2018, 01:22 PM
  4. New To Forum - Help With New A4 Needed - HELP NEEDED
    By lbaldy14 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-10-2014, 11:03 AM
  5. Help needed please :)
    By iparkes in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2010, 03:58 PM
