Thread: Previous post on Q7 transmission wiring fault/ recall / rubbing on chassis
  1. Talking Previous post on Q7 transmission wiring fault/ recall / rubbing on chassis
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Hi all
    I have a general memory of a post from a few years back where a chap had a problem with a comms cable(?) to the Q7 transmission rubbing on the chassis that ended up giving a problem. I have an intermittent comms error with the transmission that is becoming more frequent.
    Can anyone recall or remembers this post.
    I can't find it!
    Thanks!
  2. Re: Previous post on Q7 transmission wiring fault/ recall / rubbing on chassis
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    What error message do you see where? They may have mentioned it. If the in-forum search doesn't work try "site:VW Audi Forum - The #1 Volkswagen (VW) Forum Dedicated to the whole Volkswagen (VW) Group - Forum News message-words-here" in Google.
  3. Re: Previous post on Q7 transmission wiring fault/ recall / rubbing on chassis
    Jan 2014
    Leek, Staffordshire
    15 Post(s)
    Hi FortyPlus
    That was me back in May/July 2018 Q7 etron - Emission Control Warning Light
  4. Re: Previous post on Q7 transmission wiring fault/ recall / rubbing on chassis
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Quote Originally Posted by papadelta View Post
    Hi FortyPlus
    Many thanks for that. Just back from hols also & collected the Q7- e-tron now all repaired. It turned out there was a damaged canbus wire in a cable bundle in the gearbox area with an intermittent connection, thus causing random error messages: comms errors, clutch errors, NOX errors, all kinds of implausible stuff. I did suspect a wiring issue as the error usually happened when the car was active on the suspension:: a roundabout/ tight corner, etc. And the problem was getting more frequent, and the errors even more random. Quite a few hours labour in finding/ repairing this issue.
  1. Please Help Steering column fault??? Is this a recall?
    By blackdubbin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 02:09 AM
  2. Please Help Auto transmission fault
    By yorky19640 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2011, 07:59 PM
  3. Replies: 1
    Last Post: 18-08-2009, 01:19 PM
  4. Ref Previous Post
    By BIGSOB in forum Audi A3 - Archive Topics
    Last Post: 21-07-2008, 06:49 PM
  5. A4 2001 abs/transmission fault
    By hotrod37 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-12-2007, 12:55 AM
