Thread: No Radio on car startup when car play connected
Results 1 to 8 of 8
  1. No Radio on car startup when car play connected
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Hi all, looking for some guidance with my A6 C8 with a niggle that is starting to grate! Whenever I start my car the MMI never plays the radio, even when it was the last source when the car was turned off. I soon realised this behaviour only occurs when my iphone is with me as that automatically connects. Without my iphone the radio plays correctly when the car starts up. So it would seem the connection to Car play stops the radio from firing up. I then have to manually select the radio station and all is well and the radio play.
    Does anybody else have this? Is there a way of running car play that doesn't impact the initialisation of the radio?
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  2. Re: No Radio on car startup when car play connected
    Apr 2009
    Surrey
    183 Post(s)
    Is the car going to CarPlay when you start up or is it starting in normal MMI mode? If it is starting in MMI more then it may be that the car is actually selecting bluetooth streaming from the phone and you may have that stream on pause if you have just been listening to something on the phone before you got in the car, perhaps on bluetooth headphones.The car then thinks you want to carry on listening to that stream in the car. They actually pausing the media play on the phone before you get in the car and see if that solves the issue
  3. Re: No Radio on car startup when car play connected
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Good suggestion, but I haven't been playing anything via bluetooth.
    The car starts up in normal MMI mode, on the Home screen.
  4. Re: No Radio on car startup when car play connected
    Apr 2009
    Surrey
    183 Post(s)
    That rules out CarPlay. Try turning off Bluetooth Streaming in the MMI settings and see if that solves it. If it does then maybe worth deleting the phone from the. car and the car from the phone and then re-pairing then to see if that resolves the issue
  5. Re: No Radio on car startup when car play connected
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    If I turn off Bluetooth on the iPhone and start the engine, the Radio then plays correctly :-) Unfortunately Car Play then doesn't connect as it needs Bluetooth to work. The minute I turn on Bluetooth and establish a connection to the car via Car Play, the radio turns off and the GUI interface switches to Car Play, which I guess is fair enough.
    So it seems the Car Play connection is affecting the Radio from playing on startup when it is connected.
  6. Re: No Radio on car startup when car play connected
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    I think I've sorted it. It turned out to be caused by the Audi app on the iPhone. It noticed by luck that it was launching whenever I started my car and was taking control of things! I disabled the MMI connection over Wifi within the Vehicle Settings of the Audi app and that allows the Radio to play normally when I started it. I also disabled audio play within the Bluetooth settings of the MMI, but I don't think that changed anything as when I turned it back on again the Radio continued to play ok.
  7. Re: No Radio on car startup when car play connected
    Apr 2009
    Surrey
    183 Post(s)
    Excellent
  8. Re: No Radio on car startup when car play connected
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Quote Originally Posted by gav28uk View Post
    I will try this on mine as it drives me mad, Carplay Launches then have to go back the the radio or USB and get the music going again then restart Carplay. cheers
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  1. Question Radio Station Default on Startup
    By owenmccormack in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 20-07-2017, 11:07 PM
  2. MMI2 Radio/CD Always On at Startup
    By rictic68 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-11-2013, 04:44 PM
  3. Please Help RCD 200 radio doesn't play MP3
    By lockheed in forum In Car Entertainment
    Last Post: 03-06-2013, 04:20 PM
  4. IO Play and A6 C5 Concert Radio
    By trogi79 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2011, 10:27 AM
  5. Replies: 1
    Last Post: 07-12-2008, 03:27 PM
