Thread: Transmission output shaft seal
  1. Transmission output shaft seal
    Feb 2017
    Norway
    Does anyone know the part number for the tiptronic output shaft seal on the right side? 1998 2.4 FWD saloon.
  2. Re: Transmission output shaft seal
    1840 Post(s)
    Gearbox code?
  3. Re: Transmission output shaft seal
    Feb 2017
    Norway
    ZF 5HP19 (Audi 01V). I read that the right side is the differential and the left side is the gearbox. Right?
  4. Re: Transmission output shaft seal
    1840 Post(s)
    Right is 01V 409 399 and left is 01L 409 399
  5. Re: Transmission output shaft seal
    Feb 2017
    Norway
    Thank you so much. Cheers.
  1. Please Help A6 2.5TDI quattro (Auto) main prop shaft output seal?
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2017, 10:23 AM
  2. Transmission control unit or transmission output sensor?
    By yase12 in forum New Member Introductions
    Last Post: 29-08-2014, 08:24 PM
  3. Transmission Output Speed Sensor Problem
    By bobh6742 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2013, 07:40 PM
  4. Question Drive shaft oil seal
    By Phil her up in forum Alhambra
    Last Post: 04-07-2011, 10:13 PM
  5. Drive Shaft oil seal
    By john.learmonth@ in forum Golf MK2 - 1984 - 1992
    Last Post: 23-03-2008, 05:15 PM
