Thread: Manifold issue with VCDS results
Results 1 to 9 of 9
  1. Manifold issue with VCDS results
    Mar 2018
    London
    Hi everyone,
    My A6 C6 4F 3.0l quattro TDI has been randomly lighting the engine management light and becoming more and more persistent.
    Car drives just fine, but I had it scanned and these are the results:
    012597 - Intake Manifold Runner Control
    P3135 - 001 - Lower Stop not Reached
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 48
    Reset counter: 255
    Mileage: 106878 km
    Time Indication: 0
    Date: 2022.06.03
    Time: 18:00:37
    Freeze Frame:
    RPM: 756 /min
    Torque: 62.4 Nm
    Speed: 0.0 km/h
    Voltage: 13.98 V
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    Duty Cycle: 80.9 %
    I searched for this and found that it's a common problem.
    Anyone willing to advise on a solution?
    I understand that there's a repair kit for the manifold, anyone here who's done this before willing to help?
    I'm in west London but can travel a reasonable distance.
  2. Re: Manifold issue with VCDS results
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Replace or rebuild the intake manifolds, i hear you can also map them out these days
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Manifold issue with VCDS results
    Mar 2018
    London
    Anyone here willing to do it?
    I've never done it, so I would prefer to let someone with more knowledge to fix it.
  4. Re: Manifold issue with VCDS results
    Jul 2008
    Lisburn
    15 Post(s)
    there are loads of posts on here -
    the control arms have an updated end on them - i replaced mine with Audi parts, about £15 each from memory, about 5 years ago with no issues since.
    Well i say that, one of the controllers itself is now playing up so i am going to get them mapped out.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  5. Re: Manifold issue with VCDS results
    Mar 2018
    London
    I think I've sorted it.
    The intake manifold rod was disconnected at the bottom.
    I reconnected it and the engine management light disappeared.
    I let you know if it happens again.
    I wonder how it came off because it took quite some force to push it back into the small retaining ball.
    I wonder if those cowboys at Audi have something to do with it because after they changed the air filter (courtesy service after an accident) they "forgot to close the jubilee clips on the big intake hose just in the same spot.
  6. Re: Manifold issue with VCDS results
    Dec 2007
    43 Post(s)
    Arms popping off are the 1st signs of failure though, so dont get too excited yet….
  7. Re: Manifold issue with VCDS results
    Mar 2018
    London
    Well, no, I'm not getting exited, but at least I know what it is for sure.
    Are there 2 of those rods?
    I can only see one from the top.
  8. Re: Manifold issue with VCDS results
    Dec 2007
    43 Post(s)
    Yeah x2 rods 1 on each bank of 3.
  9. Re: Manifold issue with VCDS results
    Mar 2018
    London
    So the first one which had popped out is visible and accessible.
    What about the other one?
    Is it a matter of dismantling half of the car or just a few bits covering it?
  1. Question ESP & ABS & HandBrake Warning Lights - VCDS Results
    By doberman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-06-2021, 02:49 PM
  2. Measuring Block 23 VCDS - Explanation of results
    By Peter_222 in forum VCDS - General Questions
    Last Post: 30-01-2016, 10:15 AM
  3. Question VCDS O2 sensor aging and cat test results
    By h4l in forum Golf MK4 - 1999 - 2004
    Last Post: 24-10-2015, 03:45 PM
  4. Please Help VCDS Scan results
    By smoggyrich in forum Golf MK5 - 2004 - 2009
    Last Post: 21-04-2014, 08:56 PM
  5. Some VCDS results CCM some are new
    By KieranM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2012, 09:27 PM
