Thread: Power steering intermittent stiff/jerky/heavy
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. Power steering intermittent stiff/jerky/heavy
    Dec 2014
    10 Post(s)
    53 plate AVF 1.9 tdi 130 avant. It needs aux belt service and a wheel bearing so it's going into the garage soon and I wondered what if anything else to mention or get checked/changed while it's in given the below...
    Last July I heard a funny clattery noise when the car was idling but never did anything to investigate further and nothing was flagged by garage on this (plenty of other stuff!) when it went in for service and MOT. I took this video but not sure it's much use
    Shared album - ian lovatt - Google Photos
    Looking back steering became heavier until at Easter this year it started becoming jerky as well when making big/sudden turns.
    I topped up the fluid (got proper vag hydraulic fluid) as it was at min mark when cold which I understood to be ok but more can be added.
    Seemed to work ok for a few weeks then same symptoms started again. Noticed it on longer journeys and with regular short trip use but sometimes after it's sat for a couple of days steering is ok for a while before problems kick off again.
    I can't hear the clatter any more and there's no other scary noises that other threads mention when steering.
    I've tried to test alternator clutch by moving fins with a screwdriver and sure enough it only span one way and not the other.
    Car wasn't used for a few days in a row this week then today when wife got back from short trip to town she said steering seemed ok. I tried dry steering lock to lock a few times idling sat on the drive and it seemed smooth.
    It seems the steering gets "better" after having a "rest" for few days?!
    Thanks for any advice,
    Ian
  2. Re: Power steering intermittent stiff/jerky/heavy
    Dec 2014
    10 Post(s)
    Car's booked in next week for service and aux belt change plus investigating this steering issue and what I think is a wheel bearing.
    Any thoughts appreciated.
    Cheers,
    Ian
  3. Re: Power steering intermittent stiff/jerky/heavy
    1840 Post(s)
    The symptom is certainly redolent of a failed alternator one way clutch fault, but you have tested it and it works. I would still suggest belt, tensioner, and pulley to see how that affects the steering.
  4. Re: Power steering intermittent stiff/jerky/heavy
    Dec 2014
    10 Post(s)
    Thanks for the input Crasher. I'll pass that on to the garage and see what they reckon.
    Cheers,
    Ian
  5. Re: Power steering intermittent stiff/jerky/heavy
    Dec 2014
    10 Post(s)
    So I think the rattle and the lumpy steering are two different things.
    The garage said the alternator clutch pulley and tensioner seemed fine but that the rack is the cause of the steering issues. They said it's rough lock to lock and there's excessive play on both inner rack arms.
    Annoyingly I couldn't make the heavy/jerky symptoms happen when I took it for a test drive with the mechanic but does that seem a reasonable diagnosis by the garage?
    Seems the rack has been the cause of others steering woes:
    Audi A4 noisy power steering - Page 2
    Please Help "Groaning" when turning steering wheel
    Just topped up my power steering - Page 2
    The rattle is definitely coming from the AC compressor. When I had it up on the ramps the rattle changed to a clanky whirr when I turned the AC on to max. Guess I'll start another thread for that...
  6. Re: Power steering intermittent stiff/jerky/heavy
    Dec 2014
    10 Post(s)
    Rattle from AC compressor doesn't seem to merit another thread I'm fairly certain it must be similar to these:
    Please Help Rattle when air con turned off
    Where to get cheap used/reconditioned air con compressor?
    https://www.vwaudiforum.co.uk/forum/...pressor+rattle
    If this compressor pulley is a relatively cheap fix then hopefully it's just the rack that'll kill my wallet. Garage quoted ~£700 (split 50/50 part and labour)
  7. Re: Power steering intermittent stiff/jerky/heavy
    Dec 2014
    10 Post(s)
    Hit a bit of a dead end but posted question on this thread as it seemed best place
    Please Help Rattle when air con turned off - Page 3
  8. Re: Power steering intermittent stiff/jerky/heavy
    I have a Audi A4 1997 2.4 and it seems the RHD steering rack is leaking ATF fluid - is there a rubber o ring repair kit ?
    Also anyone know why the RHD re- cond etc racks are just not available but Lhd - I have a huge choice ??
  9. Re: Power steering intermittent stiff/jerky/heavy
    1840 Post(s)
    Assuming it is front wheel drive, there is only one version, 8D2 422 052 A and this is obsolete from Audi UK both in new and exchange versions, not available from the manufacturer ZF or even Audi Tradition. due to ZF expanding and buying competitors the EU got ****** about market monopolies and made ZF sell the Lenksysteme devision to Bosch (a small company you may never have heard of) at which point the supplies of old ZF steering spares in the UK went from great to ****. The only company I can recommend is https://shop.westernpowersteering.co.uk
    1 1 0
  10. Re: Power steering intermittent stiff/jerky/heavy
    Slava thanks so much , you explained everything . I'll try western power . Andrew
  1. Power Steering Stiff???
    By Josh Stockwin in forum Golf MK4 - 1999 - 2004
    Last Post: 31-12-2014, 06:08 PM
  2. Question Power Steering pump stiff when cold
    By sdthorne1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2011, 04:49 PM
  3. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  4. Power steering stiff when hot
    By sk1982 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2008, 08:57 AM
  5. Stiff Power Steering
    By jrwilshire2003 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-04-2007, 09:11 PM
