Thread: Wiring harness getting old
  1. Wiring harness getting old
    Sep 2020
    South Yorkshire, UK
    Starting to have some electrical gremlins. Cant really complain as my 2002 A4 B6 1.8T AVJ is 20 years old. I had a cam positioning sensor error which was caused by the wiring at the plug end of the CCT. In looking up the connector the part number is 443 906 232. I can find the connector ok but there are no repair kits with pigtails to splce in.
    Anyone if there is such a repair part?
    Thank you for your comments. Anything that can help would be appreciated.
  2. Re: Wiring harness getting old
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    The repair wires are a separate item that fits many different plugs. These should fit that one:
    • 000 979 133: 1.0 sq.mm wire, flat contact 2.8mm (optional suffixes A = Gold plated, B = High temperature, AB = both)
    • 000 979 225: 2.5 sq.mm wire, flat contact 2.8mm (optional suffix A)
    • 000 979 217: 2.5 sq.mm wire, flat contact 3.5mm
  3. Re: Wiring harness getting old
    Mar 2010
    Derry ireland
    60 Post(s)
    The cam sensor on this model shares its 5v feed with boost pressure sensor & the brake servo pressure sensor & is earthed via pin 3 to ecu pin no 108 Curious to know how you checkedout connector plug
  4. Re: Wiring harness getting old
    Sep 2020
    South Yorkshire, UK
    Hi Mickeybo,
    The cam positioning sensor was replaced with a Bosch one about 3 months ago. This did not resolve the issue. Kept the old one as hall sensors rarely go bad. Funny enough I was checking all the connections related to that problem. When I checked the CCT solonoid i found thet one of the 2 wires had a break in it. Temporally spliced it , cleared the codes and have not had a problem since. Simple trouble shooting. Being as both my front door harnesses had to be repaired, Tropran Kit, I realized that a 20 year old harnes would have some wear and tear. Being as that connector is on the back of the engine I realised that the engine heat would probably be a major contributing case of the failure. I have ordered 5 replacement pig tails from my local dealer as the Injector plugs are the same.
  5. Re: Wiring harness getting old
    Sep 2020
    South Yorkshire, UK
    Thank you for the information. Where did you find that at?
  6. Re: Wiring harness getting old
    1840 Post(s)
    He has ETKA, the VAG parts system.
  1. Headlamp wiring harness
    By Glebedriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-09-2020, 06:51 PM
  2. What wiring harness do I need?
    By paradisiac82 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-12-2017, 11:01 PM
  3. HELP HELP HELP - Glowplug Wiring Harness?????
    By Warrenmole in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-07-2011, 11:31 AM
  4. Wiring harness for gt tdi ajm
    By NAZZA69 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-11-2009, 06:38 PM
  5. stereo wiring harness
    By otis_b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2007, 02:20 PM
