Thread: 2007 Passat B6 2.0 TDI Re-installing twin balancer gear driven oil pump.
  1. 2007 Passat B6 2.0 TDI Re-installing twin balancer gear driven oil pump.
    Oct 2020
    Lingfield, Surrey
    Hi, only my 2nd
    post so please don't shout at me if I've put this in the wrong section. I had oil pump failure about a month ago and finally got around to taking the sump off yesterday and having a look. The 77mm hex shaft has rounded off so I have ordered a new one. I was a bit silly as I removed the whole pump assembly even though I didn't need to. My question is when I re-install the pump assembly do I have to worry about timing it to the crankshaft or doesn't it matter. I have spent all day hunting but can't find the info online. Also for some mad reason I loosened the four bolts holding the gear on the end of balance shaft 1 and notice that the bolt holes are elongated, just wondered why this is. Any help would be gratefully received.
  2. Re: 2007 Passat B6 2.0 TDI Re-installing twin balancer gear driven oil pump.
    132 Post(s)
    1979 Post(s)
    If you are just replacing the hex as a short term temporary repair then no timing required.
  3. Re: 2007 Passat B6 2.0 TDI Re-installing twin balancer gear driven oil pump.
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    I believe the intermediate gear has been removed / loosened and the OP will need to reinstall it correctly with the correct clearance / lash with the crank and lower gears will he not Mr C?
    Mad Mitch
  4. Re: 2007 Passat B6 2.0 TDI Re-installing twin balancer gear driven oil pump.
    132 Post(s)
    1979 Post(s)
    The book says fit a new gear, hold it firmly in mesh with both gears and tighten.
  5. Re: 2007 Passat B6 2.0 TDI Re-installing twin balancer gear driven oil pump.
    Jan 2012
    10 Post(s)
    88 Post(s)
    Thought that was the case, thanks Crasher
    Mad Mitch
  6. Re: 2007 Passat B6 2.0 TDI Re-installing twin balancer gear driven oil pump.
    132 Post(s)
    1979 Post(s)
  1. Please Help Passat 2.0 tdi bkp oil pump balancer shaft?
    By johnbatman520 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-04-2016, 06:04 AM
  2. Worried about balancer shaft problems in my 2007 (BRE) 2.0 A4 been
    By captainchoas in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-12-2014, 01:03 PM
  3. BKP 2.0 TDI 140 intermediate gear failing on oil pump/balancer assy.
    By Josho in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-07-2014, 10:05 AM
  4. Please Help passat 2007 2nd gear jump twice before shifting to 3rd gear
    By tsaleh01 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-02-2013, 11:02 PM
  5. Oil pump balancer shaft
    By mission66 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-08-2010, 08:10 AM
