Thread: VW Jetta 2008 2.0 140bhp BKD P0234+P0401
  1. VW Jetta 2008 2.0 140bhp BKD P0234+P0401
    Jun 2022
    Ireland
    Hi all bought a Vw Jetta not so long ago and the P0234 code was coming up and the car was going into lim at about 120-150km( just turned the ignition on and off to reset it) turbo went on the car eventually, I bought a used turbo and got a mechanic to install it for me Iím having the same problem, the turbo also had a barely noticeable whistle to it spoiling up, but now I have a P0401 as-well, i took the egr off and clean it out thoroughly and made sure the valve was working, reinstalled it and still the same unfortunately, im thinking maybe the diaphragm has failed. I also used a fuel additive turbo cleaner and still no results any ideas or theoryís welcome please
  2. Re: VW Jetta 2008 2.0 140bhp BKD P0234+P0401
    Apr 2014
    SW London / Surrey
    6 Post(s)
    143 Post(s)
    The P0234 is probably "sticky vanes" inside the turbo unless it was opened up and cleaned well prior to install. I fixed it on one of ours by starting to use the car for a daily 50km commute on the motorway. The extra heat and whizz sometimes clears out the soot that makes it sticky.
    For the P0401 which part of the EGR system did you look at? I fixed ours by removing the EGR cooler at the back of the engine and cleaning it out - it was packed full of soot. The valve near the air intake manifold is not related to this. BTW, this soot is incredibly black and staining - the clothes I was wearing at the time ~2 years ago have had numerous washes since and it still hasn't washed out.
  3. Re: VW Jetta 2008 2.0 140bhp BKD P0234+P0401
    81 Post(s)
    1388 Post(s)
    The BKD is VERY prone to carbon fouling of the turbo vanes, as far as a fuel additive goes with cleaning the turbo, you would have just as much success if you told the car a bedtime story. With the turbo having been changed and you now getting P0401, make sure the code P0234 has not changed to P0235 as the symptoms are the same but the cause different.
    Slava Ukraini!
  1. Question EGR removal, clean and remap 2008 2.0 140bhp TDI
    By Paul Rout in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2020, 09:21 AM
  2. 2008 A3 Code P0234
    By Sullydog in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-03-2018, 02:02 PM
  3. Question Buyers advice - B7 2008 2.0tdi 140BHP
    By aerotec in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-02-2018, 09:48 PM
  4. Volkswagen Jetta 2007 Jetta 2.0 TDI 140BHP Knackered Turbo?
    By VolksPolo in forum VCDS - General Questions
    Last Post: 10-11-2017, 02:11 PM
  5. Spare key for 2008 Jetta.
    By ulsterfry in forum Jetta MK3 - 2005 - 2013
    Last Post: 22-01-2012, 02:25 AM
