Thread: Golf Mk6 Cabrio Poor Radio Reception
  1. Golf Mk6 Cabrio Poor Radio Reception
    Kettering, Northants
    My wife's 2013 Mk6 Golf cabrio has been suffering poor radio reception for some time, whilst she is sort of happy streaming via Bluetooth it does consume mobile data and anyhow, the radio should work properly. With diagnostic help from Crasher, I have replaced both aerial amplifiers (in the A pillars on a cabrio, not the tailgate or boot lid) so those as individual parts are ruled out, a similar drop in signal quality on my own Mk6 hatch was one of the aerial amps. The car has recently had a new windscreen (which has the aerials in it) but the problem was there before that. The head unit ahs never been taken out. VCDS shows no faults.
    Has anyone got any ideas where to start looking for a bad earth or damaged wires in the loom?
    There are 3 kinds of people in the world, those that can count and those that can't.
  2. Re: Golf Mk6 Cabrio Poor Radio Reception
    Apr 2014
    SW London / Surrey
    6 Post(s)
    144 Post(s)
    I'd try and rule out the head unit first. Do you have an alternate FM aerial like one of the "T tape" ones that often come with a house mini-hifi unit? One wire from it held in the centre of the aerial connection with a cocktail stick whilst the other is touched to the outside should give a decent signal. Or just get an aftermarket DAB / FM car aerial to see if it helps. If so they will often work quite well if tucked behind the glovebox, etc.
    In case you're new to this, radio signal co-ax "guides" radio signals rather than "conduct" them. In practice that means that crushed or bent co-ax suffers large signal loss. Nice round cable with gentle bends is what you're aiming for.
  3. Re: Golf Mk6 Cabrio Poor Radio Reception
    Thanks for that. I have tried using a Pure Highway which received DAB but connects via FM to the head unit but even as a local signal source it was still poor. I'll run a trace on the coax. There has been no work behind the dash area in the 3 years we've had the car but I guess a cumulative area of damage dating right back to a small kink or crush in earlier work or even at build, might have caused it to get worse over time.
  1. Poor radio reception
    By davlin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-09-2011, 11:57 AM
  2. Poor radio reception
    By PETER G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2011, 11:14 PM
  3. Poor FM/AM radio reception
    By Herbiv4 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-04-2009, 09:16 PM
  4. Poor Radio reception.
    By cloughie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-08-2008, 07:28 PM
  5. poor radio reception on aftermarket radio
    By pukrik3@pukrik3 in forum New Member Introductions
    Last Post: 23-07-2008, 09:21 AM
