Thread: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
Results 1 to 10 of 11
Threaded View
  1. 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    Aug 2016
    Birmingham
    My car is a 2018 24k miles and I have coolant leak on right side of engine just above bell housing, coolant level warning light came on. I checked engine bay and it seemed nothing obvious until I noticed that coolant had been weeping collecting onto the bell housing.
    Having read a few posts now it’s apparent coolant leak is a common issue mines leaking oil on the right side of engine when standing in front of car.
    Cars lost half litre and did not overheat. The hoses don’t seem to be leaking. Having read numerous posts stating that the housing is a common issue. Is it the gaskets that perish ? Because I managed to find a supplier for the gaskets ? I don’t fancy purchasing a whole housing just because of gaskets or is it the case the housing warps ?
    My housing seems to be made of metal not plastic.
    I’ve attached pic of replacement thermostat waterpump housing and the replacement gasket and link for gaskets anyone with similar issue.
    Someone pls advise if I can get away with just replacing gaskets
    thanks in advance
    thanks in advance
    Last edited by Crasher; 21-06-2022 at 11:50 AM. Reason: So old gits like me don't have to squint...
  1. Please Help Passat 2012 B7 1.6 tdi water / coolant leak at oil cooler housing
    By Strath44 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 12-12-2018, 01:13 PM
  2. draining coolant to replace thermostat then reusing?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2014, 04:04 PM
  3. If replacing the Thermostat housing on 1.8T, always replace the plastic plug behind it.
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-03-2014, 08:45 PM
  4. Coolant leak possibly from plastic piece just to left of thermostat housing
    Last Post: 03-03-2014, 10:35 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
