Thread: Oil drain vale: Yay or nay?
  1. Oil drain vale: Yay or nay?
    Jan 2013
    N/A
    Just did oil and filters change (oil, fuel, cabin and air). I extracted old oil from the dip stick using an electric pump. I'm convinced I got most of the oil out (4L of new oil went in + 250mL top up after 10min drive to hit the 3/4 fill on the dip stick).
    A quick search on Google for the next oil change (planned to do it from the sump for complete drain) got me to a "valved" sump plug such as these:
    Fumoto (US):
    Valvomax (US):
    Stahlbus (Germany):
    The idea is great; once fitted, no need to fettle with the drain plug, open the valve and out comes the oil. Reduces the risk of cross threading, faffing with which copper washer to get, clean oil drain, etc.
    Major downside is they cost around £30-40! Very little distributors in the UK and online shops like eBay and Amazon are full of minefield with genuine vs counterfeit (I wouldn't trust a cheaper versions as I'd assume they'd cause leakage)
    Is it simply a matter of cost that this idea is not widely accepted in cars, especially in the UK?
    Given that sump plugs can be bought for £3 (Washers in pences if bought in bulk), does it persuade someone for an intestment of ~10 oil changes?
    What do you think?
    '11 VW B7 Passat Estate 2.0TDi CFFB (Current)
    '98 VW T4 Transporter 2.5TDi ACV (Previous)
    '99 Audi B5 A4 Avant 1.9TDi AFN (Previous)
  2. Re: Oil drain vale: Yay or nay?
    134 Post(s)
    2021 Post(s)
    Nope, stick with a bung
  1. Oil Leak vale cover/rocker cover
    By hunterczt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-07-2016, 06:51 PM
  2. Please Help 3.0 v6 variable vale problem
    By a4votex in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2015, 09:50 PM
  3. A8 3.0 tdi oil drain
    By A8-TDI in forum A8 - S8 - V8
    Last Post: 20-10-2010, 10:23 PM
  4. Air con drain
    By Dave996 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-09-2010, 11:14 PM
  5. Please Help air con drain
    By davec573 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-07-2009, 04:17 PM
