Thread: engine overheating at over 40mph
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: engine overheating at over 40mph
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    I think the main thing to work out is why the engine was overheating. If you get the original water pump out and the impeller is damaged in some way that hopefully means the new pump will fix the core problem. If impeller parts are missing then you may need to think about which bits to flush which way to recover them. So for now I'd just focus on getting the pump out to see if it explains what was wrong.
    You don't happen to have any kid of winter pack with extra warmers do you? No immediate problems come with that to mind - but it might help others think about which valves might be flaky.
  2. Re: engine overheating at over 40mph
    Apr 2016
    London/UK
    23 Post(s)
    Quote Originally Posted by VAG-Abound View Post
    it's a plain black edition . no winter packs added. i have aux heater and heated seats though
    after washing the car today, drove it for 7hrs. started early morning 5am till about 1pm.
    went as fast as 55mph. nothing , no errors, no overheating, dial stayed at 90
    as soon as the sun comes out, from 16degrees onward, my air con is playing up. starts blowing less and less cold air till it turns to warm (warmer then the outside temp)
    stopped and moved the flow all 3 stages (lower/ front/windshield) : low is cold(ish)and front and windshield is warm air.
    every time i turn the ac unit off and then on, it blows cold for a few sec and then it turns to warm
    i've replaced the front radiator aircon pressure sensor yesterday
    now , after reading about overheating coolant online, does audi has a safety cut thingy that blows hot air inside just to cool down the engine?
    many managed to drive the car home when engine was overheated just by turning heat on full blast. is this smtg that comes as a safety feature rather then an indy trick?
    also low oil pressure warning comes on quite often when the sun is out and car comes to a stand still . i have both sensors just don't know where they are to replace them. i've looked 2 hrs yesterday, can't see anything around the oil filter casing
    can my oil pump be on the blink and trigger the overheating issues?
    i remember 2 weeks ago, while doing 70mph, i've switched to manual mode and let it go for 30sec or so at about 2400rpm's. coolant temp went to 120 and after i've switched it back to auto and hence lowered the revs, after a min or two coolant went down to normal 90. no red warning though
    i don't have an oil pressure gauge or the skills to use one. can i do anything in vcds to check idle values and driving ones too for coolant and oil.
    i've done live measuring values for abs sensors but dont know which ones to chose for coolant and oil and also which are normal values to compare mine against
  3. Re: engine overheating at over 40mph
    1837 Post(s)
    Can you post a full VCDS scan?
  4. Re: engine overheating at over 40mph
    Apr 2016
    London/UK
    23 Post(s)
    hi. there's nothing in there. empty
    just my rooftop antenna with rusty connection
    drove it ever since and done a motorway trip at 70mph. coolant was at 90 and aircon went down when outside was 18degrees+
    i've topped up the coolant level with about 300ml though, so now it sits a little bit above the MAX level
    £65 later, found out that my AC was just low on gas and needed a refill...
  1. Audi A3 8L AVU Engine - Overheating
    By rooney353 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 05-09-2014, 06:22 PM
  2. 1.6 (AKL) engine overheating
    By tripty in forum Golf MK4 - 1999 - 2004
    Last Post: 10-04-2013, 10:15 PM
  3. Question TDI engine overheating
    By ron french in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2011, 06:22 PM
  4. Overheating Mk3 1997 AEE Engine
    By Gillman in forum Golf MK3 - 1993 - 1999
    Last Post: 21-11-2008, 11:51 AM
  5. Touran '04 1.6 - Engine Overheating
    By Cotswoldshire in forum Touran - Sharan - Caravelle
    Last Post: 14-03-2008, 06:09 PM
