Thread: Pipe under drivers side with signs of leakage
  1. Pipe under drivers side with signs of leakage
    Jun 2022
    Haywards Heath, England
    Hi all, I'm looking for a bit of help
    there's a pipe under the drivers side of the car that seems to have signs of leakage, the front of the pipe looks like this
    Further back it looks like it's had a leak
    My wife drove over something in the road and said there was a quite loud clonk under the car, can anyone tell me what this pipe is, and what's its holding?
    I am now also loosing a small amount of water and can't see where that's going, but this looks like it's ribbed for cooling possibly, so that might be a coincidence and another issue
    Many thanks
  2. Re: Pipe under drivers side with signs of leakage
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    0 2 0
  3. Re: Pipe under drivers side with signs of leakage
    Jun 2022
    that it is, well it def looks like it. thank you so much for the heads up, much appreciated. So nothing to do with my water issue.... but a far greater issue if it's fuel I'm leaking at these current prices.
    Thanks again
  4. Re: Pipe under drivers side with signs of leakage
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    I assumed you'd say it must be fuel leaking then.
    If you think it is water then a few things come to mind:
    1. Rear washer hose leaking, and water escaping through floor bung. If you squirt rear washer does it take time to come through, as if the pipe has drained?
    2. Water ingress to body that has gathered under carpets / padding and escaping through bung. If so may be worth exploring if any electronic boxes are bolted to that part of floor.
    3. Water trickling along outside of line from engine, so a leak in windscreen fluid, etc. Presumably you'd have noticed a radiator leak.
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. Drivers side heating cold. Passenger side heating fine.
    By Tightpants in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2010, 09:23 PM
  3. Passenger side climate control blowing hot, drivers side ok
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-12-2009, 10:44 PM
  4. Water leakage on drivers side
    By hendy00 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-05-2008, 07:21 PM
  5. Bora 130 St - Oil Leakage Wishbone - Driver Side
    By COTT in forum Bora - 1998 - 2005
    Last Post: 22-02-2008, 06:13 PM
