Thread: P0405 - 000 - Signal too Low - MIL ON
  1. P0405 - 000 - Signal too Low - MIL ON
    Feb 2015
    United Kingdom, Oxford
    HI all,
    I am hoping someone can help me out with this.
    2008 2.0 TDI 140hp B6 Passat.
    A while back the car dropped into limp mode and the 'engine light' came on.
    I ran a VCDS scan and it showed the EGR as faulty. After removing and cleaning it, didn't solve the problem, so I purchased an after market replacement.
    This was fitted by my self and seemed to be virtually identical to the OEM part.
    After this the engine light stayed out and the car ran perfectly - for about two weeks, which in not may miles as I work from home, when the engine light came back on
    Below is the VCDS scan.
    The car runs perfectly, no loss of power or any other detectable problems and MPG is still good. I have tired cleaning the connector to the EGR valve to no avail. Resetting the code only lasts for a couple of short journeys when the light returns.
    I have exercised the EGR with VCDS and can hear it moving, but have not done this while its off so I can actually see the valve moving.
    Any ideas what can I do next to resolve this issue???
    Thanks in advance
    VCDS scan:
    Address 01: Engine Labels: 03L-906-022-CBA.clb
    Control Module Part Number: 03L 906 022 FN HW: 03L 907 309
    Component and/or Version: R4 2,0L EDC G000SG 2643
    Software Coding: 0000072
    Work Shop Code: WSC 84224 802 739910
    001029 - EGR Sensor 1
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 265139 km
    Time Indication: 0
    Date: 2022.05.31
    Time: 13:11:51
    Freeze Frame:
    RPM: 874 /min
    Speed: 0.0 km/h
    Voltage: 14.14 V
    Lambda: 99.4 %
    Lambda: -0.8 %
    Bin. Bits: 00000000
    Voltage: 0.000 V
  2. Re: P0405 - 000 - Signal too Low - MIL ON
    Mar 2010
    Derry ireland
    60 Post(s)
    Your engine code would be very much helpful
  3. Re: P0405 - 000 - Signal too Low - MIL ON
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    There are views on places like the Ross Tech forum that non-VAG parts are prone to giving that error.
    My preference on our similar aged car is to find a genuine part from a breaker via eBay if DIY fitting. There's a decent chance that it will work just fine. I can't think of anything I've had that way that didn't work out.
  4. Re: P0405 - 000 - Signal too Low - MIL ON
    1840 Post(s)
    We refuse point blank to fit aftermarket EGR units. on the CBAA and CBAB this was originally 03L 131 501 D, then E, then G and now K and at a guess you fitted something like the Euro Car Parts 42444043S? We will fit Pierburg if pushed, when we can get them
  5. Re: P0405 - 000 - Signal too Low - MIL ON
    Feb 2015
    Many thanks for all the responses people.
    Looks like I need to get either a second hand or new OEM EGR - rats!
    Still cheaper than having a garage figure that out
    Regards
    Paul
  6. Re: P0405 - 000 - Signal too Low - MIL ON
    Feb 2015
    Thanks for the advice. Purchased a second hand OEM part from ebay and that fixed it.
    Cheers guys.
  1. Replies: 14
    Last Post: 07-10-2023, 12:01 PM
  2. EGR P0405 - Where to start.
    By fattyballaty in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2021, 02:03 PM
  3. Question Continuous turn signal.... electrical signal
    By SammyKat in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-11-2017, 04:29 PM
  4. Replies: 0
    Last Post: 17-11-2014, 04:33 PM
  5. A6 2.0tdi fault P0405 help!
    By R4bmcg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-03-2014, 09:19 PM
