Thread: Audi a3 p2108 fault code
  1. Audi a3 p2108 fault code
    Jun 2022
    United kingdom
    Hello everyone,
    So essentially my audi a3 2.0tdi bkd had the engine codes p2100 and p2102.
    This led to me changing the throttle body and cleaning the egr valve. I also changed the fuse and performed an ecu reset.
    After this had all been done, i took the car for a drive and noticed it was laggy and the car would fully turn off at points. Using my carista, i cleared any faults to which p2108 flagged up. Ive also noticed the radiator fan now keeps spinning at full speed.
    Does anyone know how to fix this fault or any thoughts/ideas on this?
    Thank you in advance
  2. Re: Audi a3 p2108 fault code
    Mar 2010
    Derry ireland
    60 Post(s)
    the reason your fan runs at high speed is because you have (certainly a wiring problem) This fan is fed via main engine control relay & your throttle body is inter connected to the fan your trouble codes telly you so When the wiring to throttle body is sorted it will stop your fan
  3. Re: Audi a3 p2108 fault code
    1840 Post(s)
    Does the fan come on slowly up to full speed a few seconds after turning on the ignition but not starting the engine? I don't trust the result the code reader is giving, as far as I can see this ECU should not generate this code, it is generic and non VAG specific. It would be interesting to have a code read done with VCDS to see how it compares.
  1. P2108 Error Code - Dirty Throttle Body Adapter?
    By nb99 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-09-2020, 11:09 AM
  2. Please Help Help - 2002 Audi A3 1.8t Quattro ARY engine code - Rough Idle - Fault code P1340 - Help
    By mumutley in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-05-2019, 11:10 PM
  3. Audi A4 TDi fault code
    By arabianjules in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-09-2017, 08:16 PM
  4. Please Help Error code P2108
    By pritz25 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-09-2009, 04:08 PM
  5. Question Fault code P2108?
    By dod1e in forum Golf MK5 - 2004 - 2009
    Last Post: 12-07-2008, 05:57 PM
