Thread: Drivers window fault
  1. Drivers window fault
    Jun 2022
    Kent
    I have a relay click at the drivers window motor. Checked the wires in the door **** and they all good and two thicker wires have continuity to motor. Not sure if the motor/circuit unit is faulty or the wiring. There is a +9v down one of the fatter wires with ign on but the other one is 0v. Is this correct or should there be a positive down both wires?
  2. Re: Drivers window fault
    1841 Post(s)
    A?
  1. Question Drivers door control only operates osr window up and down and nsr window down
    By M11dvd in forum Vehicular windows, Glazing and Tinting
    Last Post: 19-03-2022, 11:28 PM
  2. Drivers side electric window fault
    By 543nisco in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-09-2010, 02:16 PM
  3. Please Help Passat drivers window fault
    By webbo1974 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2009, 06:14 PM
  4. Drivers window mechanical fault!
    By Rogg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2007, 01:34 PM
  5. drivers side electric window fault
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 10-03-2007, 04:22 PM
