Thread: A4 B8.5 Allroad Starter Jammed
Results 1 to 10 of 15
  1. A4 B8.5 Allroad Starter Jammed
    Ardfern
    8 Post(s)
    On my 2016 year Allroad I have the symptoms of a jammed starter. Has anyone experienced this? I have never had it in driving almost 20 years in A4s. At first I assumed the battery was low, but overnight on charger made no difference. I’ll try rocking in gear but she is not a light car and I am only a lightweight!
    is there an accessible nut on the end of the starter motor?
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  2. Re: A4 B8.5 Allroad Starter Jammed
    1840 Post(s)
    I would be surprised if it was faulty, I would be more inclined to suspect water damage in the plenum chamber e-box.
  3. Re: A4 B8.5 Allroad Starter Jammed
    Ardfern
    8 Post(s)
    Thanks Crasher.
    Here is what is presumably the relevant bit of my scan from yesterday:
    Tuesday,31,May,2022,17:51:46:60719
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 22.3.0.1 (x64)
    Data version: 20220225 DS336.1
    Ross-Tech: Home
    VIN: WAUZZZ8K8GA001180 License Plate: SB15PDK
    Mileage: 146060km-90757mi Repair Order: 310522
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6D 72
    AC
    VIN: WAUZZZ8K8GA001180 Mileage: 146060km-90757miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    69-Trailer -- Status: Not registered 0001
    6D-Trunk Elect. -- Status: OK 0000
    AC-Reductant Control -- Status: OK 0000
    Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 BK HW: 04L 907 309
    Component: R4 2,0L EDC H23 8251
    Revision: 85H23--- CVN: E32E1D8F60B4FDC638D3FF82
    Coding: 32194012242601080000
    Shop #: WSC 06208 000 00000
    ASAM Dataset: EV_ECM20TDI01104L906021BK 002009
    ROD: EV_ECM20TDI01104L906021BK_002.rod
    VCID: 6FE6DF7DB67023F72B-803A
    VINID: 9D196AAAA21B2174400010480060E0DD8A
    6 Faults Found:
    4531 - Fan 1 Control Circuit
    P0691 00 [032] - Short to GND
    Intermittent - Not Confirmed - Tested Since Memory Clear
    5456 - Starter Will Not Turn
    P3054 00 [101] - Jammed or Electrical Malfunction
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 146060 km
    Date: 2022.05.31
    Time: 11:15:15
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 11 °C
    Intake air temperature: 14 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 6.860 V
    Unlearning counter according OBD: 40
    Starter control: terminal 50 feedback-Bits 0-7: 52
    Status of starter activation relay-Bits 0-7: 3
    Starter control: release conditions-Bits 0-7: 2
    Starter control: release conditions-Bits 0-7: 90
    Starter control: shut-off conditions 1-Bits 0-7: 0
    Number of manual engine starts-Bits 0-7: 0
    Number of automatic engine starts-Bits 0-7: 0
    Does that tell you anything further?
    Lotus Elan SE 1991
  4. Re: A4 B8.5 Allroad Starter Jammed
    1840 Post(s)
    so at 11:15 am yesterday the battery voltage was 6.86 volts...
    Can you post the full car code read after fully clearing and rescanning with the battery on charge.
  5. Re: A4 B8.5 Allroad Starter Jammed
    Ardfern
    8 Post(s)
    I’ll do that in the morning. Thanks.
    Lotus Elan SE 1991
  6. Re: A4 B8.5 Allroad Starter Jammed
    Ardfern
    8 Post(s)
    Crasher, here is the full scan after charging overnight and charger still connected and having cleared all DTCs.
    Code:
    Thursday,02,June,2022,10:23:59:60719
    Ross-Tech: Home
    Mileage: 146060km-90757mi   Repair Order: 020522(2)
    Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6D 72 AC
    01-Engine -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K9 907 379 P    HW: 8K9 907 379 P
       Component: ESP8 quattro  H09 0020
       Revision: --------    Serial number: --------------
       Coding: 12DDCC01
       Shop #: WSC 06335 000 00000
       VCID: 4FA67FFD1E3003F70B-801A
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
       Component: BCM2 2.0      H15 0711
       Revision: 00002001
       Coding: 03B24040000000000000
       VCID: 7F060F3DEE105377BB-802A
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Component: FBSAUDIB8 IDG  H71 0083
       Serial number: 3715000028702009
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Component: J764 ELV MLB  H40 0046
       Serial number: 3215000094400004
    Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
       Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
       Component: KLIMA 3 ZONEN H04 0123
       Revision: D1000000    Serial number: 01270520151960
       Coding: 342400A080
       VCID: 6AD0CE698592C6DF7C-803E
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
       Component: BCM1 1.0      H16 0103
       Revision: 08016001    Serial number: 00001081814601
       Coding: 260000108034AFE00481408300001D0D009D870827090201000008004400030100000024000000
       VCID: 78F4E421CB3E644FFA-802C
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 130515  H06 0080
       Serial number: SWF15055135619
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0004
       Serial number: 20318678
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000805150479
       Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H03 0003
       Serial number: 67B8CBA7000000000001
    1 Fault Found:
    01629 - Sensor for Parking-Aid; Front Left (G255)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 177
                        Mileage: 146060 km
                        Time Indication: 0
                        Date: 2022.06.02
                        Time: 10:18:59
    Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
       Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003KFDC7NBBT
       Coding: 30534435363030303030554A3052384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
       VCID: 489454E1F35ED4CF4A-801C
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME51590F0BJ
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 6344MSME514D633CL
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 6352QSME234D3F7E
       Passenger side rear thorax airbag crash sensor:
       Serial number: 6362QSME13540F5AL
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME6F4C5744D
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME6F4C5742C
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862ODN0002S
       Coding: 000017
       VCID: 489454E1FB5ED4CF4A-801C
       Component: E221 - MFL  H03 0004
    Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 983 G    HW: 8K0 920 983 G
       Component: KOMBIINSTR.   H35 0567
       Revision: 00100000    Serial number: 61+71ZN5G
       Coding: 33A5290203012600010000
       Shop #: WSC 06335 123 12345
       VCID: 39722125B0B4BD47C5-806C
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y155190A63
       Coding: 80CF07FF00
       VCID: 4A906EE9E55226DF5C-801E
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 6023256603
       Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
       Component: J532_DCDCStab  H17 0042
       Serial number: 15146003133011200181
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 177
                        Mileage: 146060 km
                        Time Indication: 0
                        Date: 2022.06.02
                        Time: 10:19:04
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 12.10 V
                        Count: 6
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000150483826
       Coding: 011002204001410001
       VCID: 50A47C81030E1C0F12-8004
    Address 44: Steering Assist (J500)       Labels:| 8K0-909-144.clb
       Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
       Component: RCEPS         H43 0510
       Revision: 00001000    Serial number: 0026757791
       Coding: 100000010001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3E783239A19A9A7FF0-806A
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0369490309
       Coding: 013B0622A0B930408320023680000047
       Subsystem 1 - Part No: 8K0 951 177
       Component: DWA-Sensor  H02 0040
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
       Component: TSG BF        H02 0510
       Revision:             Serial number: 0000150502363
    Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 20000000630775
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A703E29BDB2B65FCC-806E
    Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109E00F8038828
       Coding: 010103020100000001
       VCID: 2B5E0B6D4AE81FD747-807E
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 8R2 035 666 J    HW: 8R2 035 666 H
       Component: H-BN-EU       H49 0941
       Revision: --------    Serial number: 515FZ0FB013435
       Coding: 100101050006A1ED05808F5E00000403E40000020000000000
       VCID: 40844CC1D36EEC8F82-8014
       Subsystem 1 - Part No: 8R0 060 884 CR
       Component: EUR 2015  2102
       Subsystem 2 - Part No SW: 8R0 919 604 A    HW: 8R0 919 604 A
       Component: DU7 High  H42 0104
       Serial number: A130E$0F3364698
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Component: E0380 Bedient  H02 0030
       Serial number: 00000002250432
       Subsystem 4 - Part No: 8R0 060 961 G
       Component: CD-Database  6208
    Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
       Part No SW: 8K0 959 795 G    HW: 8K0 959 795 D
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000151492826
       Coding: 010002204001210001
       VCID: 46885AD9F14AC2BFB8-8012
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Component: ConWys Trailer H09 0100
       Revision: 1A001001    Serial number: 00000161077413
       Coding: 0100000000000000
       Shop #: WSC 00007 223 57222
       VCID: 36682A1981AA523F28-8062
    Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
       Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8K9827851C
       VCID: 3E783239A99A9A7FF0-806A
       Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
       Component: J756  Slave  H53 0330
       Serial number: 8K9827852C
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000151492876
    Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 151300765
       ASAM Dataset: EV_RDCMA00100 008040
       ROD: EV_RDCMA00100.rod
       VCID: 2D5A05757CFC11E759-8078
    End-------------------------(Elapsed Time: 03:47)--------------------------
    Lotus Elan SE 1991
  7. Re: A4 B8.5 Allroad Starter Jammed
    Ardfern
    8 Post(s)
    I should also mention that after this the non-starting symptom persists.
    Lotus Elan SE 1991
  8. Re: A4 B8.5 Allroad Starter Jammed
    1840 Post(s)
    So those are the only codes which have returned even after a few attempts at starting it? Do you have a code read from the days when it used to run?
  9. Re: A4 B8.5 Allroad Starter Jammed
    Ardfern
    8 Post(s)
    Here is a log from earlier this year:
    Tuesday,01,February,2022,15:20:59:60719
    VCDS Version: 21.9.0.2 (x64)
    Data version: 20210903 DS330.0
    Ross-Tech: Home
    Mileage: 136140km-84593mi Repair Order: 010222
    AC
    VIN: WAUZZZ8K8GA001180 Mileage: 136140km-84593miles
    ROD: EV_ECM20TDI011_AU48.rod
    VCID: 6FE6DF7DB67023F1A8-803A
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 134319 km
    Date: 2021.09.14
    Time: 19:23:39
    Engine RPM: 933.50 /min
    Normed load value: 49.4 %
    Coolant temperature: 14 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 12.500 V
    Unlearning counter according OBD: 6
    Air mass: specified value: 250.0 mg/stroke
    Coolant temperature sensor 1: B1: on radiator output: raw value: 2222.0 °C
    Heat delivery temperature in cooling system: -273.1 °C
    Outside temperature sensor 1: B1: raw value: 9.0 °C
    Coolant fan 1: activation: 10.20 %
    Fuel temperature sensor 1: B1: raw value: 10.3 °C
    4635 - Engine Oil Temp. Sensor (G8)
    P0196 00 [032] - Implausible Signal
    4637 - Engine Oil Temp. Sensor (G8)
    4640 - Engine Oil Temp. Sensor (G8)
    P0197 00 [032] - Signal too Low
    9645 - Reductant
    P20E8 00 [096] - Pressure too Low
    Readiness: 0 0 0 0 0
    Coding: 12DDCC01
    VCID: 4FA67FFD1E3003F188-801A
    1 Fault Found:
    02214 - Tire Pressure Warning
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 17
    Reset counter: 167
    Mileage: 130323 km
    Time Indication: 0
    Date: 2021.06.13
    Time: 13:31:50
    Freeze Frame:
    Hex Value: 0x3800
    Hex Value: 0x4006
    Hex Value: 0x1221
    Hex Value: 0x1FB5
    Hex Value: 0x0000
    Revision: 00002001
    VCID: 7F060F3DEE10537138-802A
    Coding: 342400A080
    VCID: 6AD0CE698592C6D9FF-803E
    Coding: 260000108034AFE00481408300001D0D009D87082709020100 0008004400030100000024000000
    VCID: 78F4E421CB3E644979-802C
    Coding: 00FD11
    Coding: 02005D
    VCID: 489454E1F35ED4C9C9-801C
    Coding: 000017
    VCID: 489454E1FB5ED4C9C9-801C
    Coding: 33A4290203012600010000
    VCID: 39722125B0B4BD4146-806C
    Coding: 80CF07FF00
    VCID: 4A906EE9E55226D9DF-801E
    2 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 130281 km
    Time Indication: 0
    Date: 2021.06.08
    Time: 16:45:32
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 12.00 V
    Count: 6
    03041 - Energy Management Active
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 7
    Reset counter: 165
    Mileage: 135446 km
    Time Indication: 0
    Date: 2021.12.04
    Time: 10:03:23
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 11.80 V
    Count: 10
    VCID: 50A47C81030E1C0991-8004
    VCID: 3E783239A19A9A7973-806A
    1 Fault Found:
    2305 - Function Restriction due to Start Voltage Interruption
    U1410 00 [008] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 135408 km
    Date: 2021.11.10
    Time: 11:27:05
    Write only channel
    VCID: 3A703E29BDB2B6594F-806E
    VCID: 2B5E0B6D4AE81FD1C4-807E
    Coding: 100101050006A1ED05808B5E00000403E40000020000000000
    VCID: 40844CC1D36EEC8901-8014
    VCID: 46885AD9F14AC2B93B-8012
    VCID: 36682A1981AA5239AB-8062
    VCID: 3E783239A99A9A7973-806A
    VCID: 2D5A05757CFC11E1DA-8078
    End-------------------------(Elapsed Time: 03:58)--------------------------
    I have removed the lid of the box of electrical gubbins at the offside of the plenum chamber. All dry in there and pretty clean but a hint of dirt on the seal at the back of the lid.
    Lotus Elan SE 1991
  10. Re: A4 B8.5 Allroad Starter Jammed
    Ardfern
    8 Post(s)
    I tried starting again a couple of times then scanned and the engine fault code has reappeared:
    Thursday,02,June,2022,17:11:56:60719
    Ross-Tech: Home
    Mileage: 146060km-90757mi Repair Order: 020622
    AC
    1 Fault Found:
    P3054 00 [167] - Jammed or Electrical Malfunction
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 146060 km
    Date: 2022.06.02
    Time: 10:29:13
    Vehicle speed: 255 km/h
    Coolant temperature: 12 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 7.220 V
    That voltage at terminal 30 is I guess the problem. Perhaps you have some idea as to where I should look next?
    Lotus Elan SE 1991
  1. jammed boot lid
    By sjpierrie in forum Bora - 1998 - 2005
    Last Post: 07-06-2012, 02:04 PM
  2. Please Help Non starter - suspect starter motor.
    By 94golfcl in forum Golf MK3 - 1993 - 1999
    Last Post: 18-01-2010, 10:09 AM
  3. Jammed Draws
    By marktj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2008, 04:32 PM
  4. Key Jammed in door
    By joanne in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2008, 08:57 PM
  5. Jammed windows B5
    By neilfc in forum Passat - Archive Topics
    Last Post: 10-06-2006, 09:04 PM
