Thread: 2020 Radio Question
Results 1 to 10 of 10
  1. 2020 Radio Question
    Jun 2009
    Andover UK
    So had a SQ7 2020 for a couple of week, one thing i can't work out, is the radio. I have set a favourite and when i leave that station in use then i lock the car.
    I get in the car and have to go to the "Radio" icon for the radio to make any sounds. Is this right or am i missing something?
  2. Re: 2020 Radio Question
    Jul 2017
    Maidstone, Kent
    47 Post(s)
    I have the same behaviour with my A6 C8. The radio won't start despite it being the last played device. I have to manually select radio each time I start the car. I think it's connected to Car play. Without my iPhone the radio play fine, but with the iPhone in the car, the radio won't play on startup.
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  3. Re: 2020 Radio Question
    Jun 2009
    Andover UK
    I will try without having the apple car play, thanks.. Must be something simple... I hope
  4. Re: 2020 Radio Question
    Jul 2017
    Maidstone, Kent
    47 Post(s)
    I discovered if I turn off bluetooth on my iPhone the radio plays normally when the car is started. Unfortunately you need Bluetooth for Car Play to connect! Doh.
  5. Re: 2020 Radio Question
    Jun 2009
    Andover UK
    How odd.... Will experiment later and see what i can find..
  6. Re: 2020 Radio Question
    Jul 2017
    Maidstone, Kent
    47 Post(s)
    I think I've sorted it. It turned out to be caused by the Audi app on the iPhone. It noticed by luck that it was launching whenever I started my car and was taking control of things! I disabled the MMI connection over Wifi within the vehicle Settings of the Audi app and that allows the radio to play normally when I started it. I also disabled audio play within the Bluetooth settings of the MMI, but I don't think that changed anything as when I turned it back on again the Radio continued to play ok.
  7. Re: 2020 Radio Question
    Jun 2009
    Andover UK
    In here do you mean?
  8. Re: 2020 Radio Question
    Jul 2017
    Maidstone, Kent
    47 Post(s)
    Yes that's the setting. Mine was enabled and turning it off appears to have sorted the radio issue.
  9. Re: 2020 Radio Question
    Jun 2009
    Andover UK
    I just turned mine off and will try when the car comes back.. Thanks again...
  10. Re: 2020 Radio Question
    Jun 2009
    Andover UK
    Mine is now fixed... Thanks again for all the help and coming up with the fix...
  1. Radio fault question
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-10-2019, 06:53 AM
  2. New Q7 M4 DAB radio question
    By Skippy73 in forum Q7 - 4M Forum - 2016 -
    Last Post: 27-05-2016, 01:06 PM
  3. concert radio question
    By gdallas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-05-2013, 12:25 AM
  4. Mk VI fuel and radio question
    By SueBee in forum Golf MK6 - 2009 - 2013
    Last Post: 14-08-2011, 02:51 PM
  5. Radio Question
    By carling650 in forum Golf MK6 - 2009 - 2013
    Last Post: 27-07-2011, 08:49 AM
