Thread: Inner tyre wear - RHS
  1. Inner tyre wear - RHS
    May 2007
    Hi - have been hearing a tick/click noise when turning the steering wheel. Noticed considerable wear on the inner section of the tyre (compared to rest of tyre). Clearly some bushing/link arm issue.. Jacked up and tried to wiggle the wheel side to side, up down but nothing very noticeable. Didn't get under with a leaver to check so just checking if there is a know common issue that ppl are aware off.
    2015 A6 C7 2.0 Tdi S-Tronic
  2. Re: Inner tyre wear - RHS
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Tyre wear could indicate front rear arms, the noise? That could be UV joint.
  3. Re: Inner tyre wear - RHS
    134 Post(s)
    2009 Post(s)
    Top, rear arm, outer ball joint wear is a big problem on these and the bolt can be an absolute ******* to get out. We did one about two weeks ago and after spending four hours with heat, cold, spray, hammer, air chisel etc, gave up and took both hubs off the car and had an engineering shop drill the 100mm long bolt out.
  4. Re: Inner tyre wear - RHS
    May 2007
    Turns out inner tie rod. Replaced & tracked.
    Sent from my MI 9 using Tapatalk
  1. Tyre wear..
    By wedgie7 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-08-2013, 09:37 PM
  2. Tyre Wear
    By sja in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-08-2011, 05:52 PM
  3. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  4. Tyre wear!!
    By pauldoherty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-12-2008, 05:36 PM
  5. tyre wear
    By Ade25 in forum Wheels and Tyres
    Last Post: 19-05-2008, 02:59 PM
