Thread: ESP/ABS/TPMS/AC/EPB fault limp mode engine hick-ups
  1. ESP/ABS/TPMS/AC/EPB fault limp mode engine hick-ups
    Apr 2016
    London/UK
    23 Post(s)
    hi there
    most times when people are getting in and diving on my back seats, i'm getting all these errors: ESP/ABS/TPMS/AC/EPB fault.
    after restarting the car, all were cleared and back to normal
    yesterday while i was driving , with a client in my rear left back seat and driving over uneven road, all these came back and now i'm stuck with all the errors again.
    i've managed to clear them at home, and then i've tried sitting there and rocked the car a bit hard.
    all errors showed up again.
    sometimes, these happens when i drive on proper roads and weather is wet or going over puddles.
    it even happened after coming out of the carwash
    i've done a vcds and checked the speed of the car (while being parked). it showed 255 km/h
    where should i start investigating?
    i can read all the errors but don't know how to "read" into faults . confirmed/temp/random....
    now this are my logs for that:
    Code:
    Sunday,15,May,2022,17:27:14:04550
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 15.7.0.2
    Data version: 20150820
    Ross-Tech: Home
    VIN: WAUZZZ4G6EN....   License Plate: 63
    Mileage: 427852km-265854mi   Repair Order: rocking car
    Chassis Type: 4G (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
              62 72
    VIN: WAUZZZ4G6EN...  Mileage: 427852km-265854miles
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0110
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    3B-Sensor Elect. -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CGLC)       Labels: 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 0A034012242401080000
       Shop #: WSC 20433 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
       ROD: EV_ECM20TDI01103L906018LB.rod
       VCID: 75F8F03785C1CF2A3CF6DF9-8020
    2 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:33
    4713 - No Communication with ABS Brake Control Module
              U0121 00 [167] - -
              MIL ON - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:33
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
       Part No SW: 4G1 927 155 P    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H05 0002
       Revision: --H05---    Serial number: 0000000996
       Coding: 000001
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_TCMVL381 A02433
       ROD: EV_TCMVL381_AU57.rod
       VCID: 39603C07E9596B4A185EA39-806C
    1 Fault Found:
    2265 - No Communication with ABS Brake Control Module
              U0121 00 [039] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:33
    Address 03: ABS Brakes
    Cannot be reached
    Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 DN    HW: 4H0 907 064 DN
       Component: BCM2 2.0      H35 0510
       Revision: 00002001
       Coding: 01B83046000000000000
       VCID: 78E6F90392D3B2C227D0FE5-802C
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:32
    Address 08: Auto HVAC (J255)       Labels: None
       Part No SW: 4G0 820 043 AK    HW: 4G0 820 043 AK
       Component: KLIMA 2 ZONEN H14 0094
       Serial number: 26101300110672
       Coding: 34210008A1
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS.rod
       VCID: 68C6A943C27322C2B770AE5-803C
    2 Faults Found:
    0247 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:34
    0330 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:31
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0130
       Revision: 20012002    Serial number: 00000001642314
       Coding: 2600201040349FE00181008300001D0C0F9DC30827090201000004606100
       VCID: 6ECADF5BE097FC72FD2C68D-803A
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A
       Component: WWS57X 131001  H36 0080
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H03 0002
    1 Fault Found:
    01316 - ABS Control Module
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:00
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0083
       Revision: 11001001    Serial number: 61031330101182
       Coding: 08C306
       ASAM Dataset: EV_EPHVA18AU57X0000 004009
       ROD: EV_EPHVA18AU57X0000.rod
       VCID: 71F0C427F1A9E30AE00E0B9-8024
    1 Fault Found:
    12656912 - Databus
              U1121 00 [009] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:33
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H43 0040
       Revision: --------    Serial number: 003JG00FDHDA
       Coding: 3032343631324E303235554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_AU57.rod
       VCID: 367A373BD8478432F57C80D-8062
       Crash sensor for side airbag; driver side:
       Serial number: 3575HRB400250N209PBR
       Crash sensor for side airbag; front passenger side:
       Serial number: 3585HRB406920N926HR9
       Crash sensor for side airbag; rear; driver side:
       Serial number: 3515JRB401E50O3SL0LK
       Crash sensor for side airbag; rear; passenger side:
       Serial number: 3525JRB401450OC8RHHJ
       Crash sensor for front airbag; driver side:
       Serial number: 3554VRB401850N8EKI9O
       Crash sensor for front airbag; front passenger side:
       Serial number: 3564VRB400A50N8GCON/
    4 Faults Found:
    1048832 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:33
    1049088 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:38
    1049344 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:36
    1049866 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:43
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
       Component: Lenks.Modul   H05 0201
       Revision: 00000000    Serial number: 20131029000154
       Coding: 000034
       VCID: 307601233A23AA82AF80C65-8064
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0010
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:34
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
       Component: MDieGb        H43 0411
       Revision: 27450259    Serial number: 658071013592029
       Coding: 33A608000B412600010000
       ASAM Dataset: EV_RBC7KMID 004048
       ROD: EV_RBC7KMID.rod
       VCID: 3F94521FF77D457A261A6D1-806A
    2 Faults Found:
    16776968 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 47
                        Reset counter: 99
                        Mileage: 427655 km
                        Date: 2022.05.14
                        Time: 13:21:24
    16776973 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 14
                        Reset counter: 99
                        Mileage: 427655 km
                        Date: 2022.05.14
                        Time: 13:20:48
    2 Faults Found:
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:37
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:28
    Address 19: CAN Gateway (J533)       Labels: None
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Component: J533--Gateway H13 0050
       Revision: --------    Serial number: 00000001138105
       Coding: 00CD074400
       ASAM Dataset: EV_GatewPkoUDS 001019
       ROD: EV_GatewPkoUDS.rod
       VCID: 72F2CB2BF4AFD81219143CD-8026
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 9267531603
       Voltage stabilizer:
    2 Faults Found:
    4352 - ABS Control Module on FlexRay Data Bus
              U10BD 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:33
    0274 - FlexRay-Data bus
              U1048 00 [009] - defective
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:23:25
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA720718EX
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2_AU57.rod
       VCID: 337C0E2FCB35911AD262E11-8066
    1 Fault Found:
    3801346 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:34
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 4G8 959 793 J    HW: 4G8 959 793 G
       Component: TSG FA        H03 0507
       Revision: --------    Serial number: --------------
       Coding: 011C16004001620002080002
       VCID: 47844AFFAFAD0D3A9EAAC51-8012
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:40
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H39 0010
       Revision: 00001000    Serial number: 0022980712
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS.rod
       VCID: 32720B2B342F9812D994FCD-8066
    1 Fault Found:
    3158273 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:34
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0317994176
       Coding: 011B062280B900008320080400010E470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    1 Fault Found:
                004 - No Signal/Communication - MIL ON
                 Freeze Frame:
                        Fault Status: 11100100
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:32
    Address 47: Sound System (J525)       Labels: None
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007001    Serial number: 00000000045716
       Coding: 010000
       VCID: 1D28C8975DB137EA1446979-8048
    1 Fault Found:
    03278 - Functionality Limited due to Missing Messages
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:56
                 Freeze Frame:
                        Bin. Bits: 00001000
    Address 52: Door Elect, Pass. (J387)       Labels: None
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0507
       VCID: 469A47FBA8A7143265DCD0D-8012
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:40
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000863203
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 2C4E1553160BCEE293D8325-8078
    5 Faults Found:
    328448 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:33
    328704 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:37
    328960 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:35
    329216 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:42
    406528 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 15
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:20
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Component: ....LWR12.... H02 0010
       Serial number: 131029-0002-015
       Coding: 112196101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D4818572D11C7EA84A6279-8078
    1 Fault Found:
    337156 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 59
                        Mileage: 427852 km
                        Date: 2022.05.15
                        Time: 17:20:36
    Address 5F: Information Electr. (J794)       Labels: None
       Part No SW: 4G0 035 192 P    HW: 4G0 035 192 F
       Component: RMC Nav Plus  H54 0818
       Coding: 0101000101415B47082B060301020100000000
       VCID: 2F74025F271DB57AB6BADD1-807A
       Subsystem 1 - Part No: 8X0 919 884 F
       Component: P23-50-13.06  0001
       Subsystem 2 - Part No SW: 4G0 919 603 A    HW: 4G0 919 603 A
       Component: DU6 Basic  H43 0084
       Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
       Component: E380 BDT C7  H11 0204
    3 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:19:37
                000 -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:40
                 Freeze Frame:
                        Bin. Bits: 00001101 00000000
                        Bin. Bits: 00000000 00000000
    03157 - Functionality limited due to Communications Disruption
                000 -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 427852 km
                        Time Indication: 0
                        Date: 2022.05.15
                        Time: 17:20:34
                 Freeze Frame:
                        Bin. Bits: 00000000 10000000
    Address 62: Door, Rear Left (J388)       Labels: None
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HL        H03 0507
       Coding: 010814004001620002080002
       VCID: 49804CC7B9B9FB4A88BEF39-801C
    No fault code found.
    Address 72: Door, Rear Right (J389)       Labels: None
       Component: TSG HR        H03 0507
    End-------------------------(Elapsed Time: 04:08)--------------------------
  2. Re: ESP/ABS/TPMS/AC/EPB fault limp mode engine hick-ups
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    My first port of call would be faulty ABS sensor, or the wiring thereto.
  3. Re: ESP/ABS/TPMS/AC/EPB fault limp mode engine hick-ups
    2007 Post(s)
    I had a similar problem on an type 8D A4 many years ago, I lifted up the back seat and found a banana skin on the ABS sensor connection plug and the pins were completely rotten. Your first step should be to check the ABS module plug and wiring against the current flow diagram.
  4. Re: ESP/ABS/TPMS/AC/EPB fault limp mode engine hick-ups
    Apr 2016
    London/UK
    23 Post(s)
    today i've spent 2 hrs rocking the car left to right and nothing happened.
    drove it with vcds on and wheel speed sensor measuring on, nada. all looked in sync
    washed it too and drove it even longer. nothing
    where's all these faults when you want them?
  5. Re: ESP/ABS/TPMS/AC/EPB fault limp mode engine hick-ups
    2007 Post(s)
    Welcome to the world of VAG diagnostics!
  1. help with these fault codes please car in limp mode epc on
    By kerrylark in forum 2.0T, TSI and TFSI - Engine
    Last Post: 09-11-2016, 12:35 PM
  2. Please Help b5 avant AFN limp mode fault finding continues
    By n1co in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-05-2016, 11:53 PM
  3. Glowplug warning / Engine fault / limp mode then Revive!
    By potshot in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-04-2012, 01:00 PM
  4. fault code and limp home mode
    By kstead in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-09-2010, 07:54 PM
  5. Vw Sharan Auto Gearbox Fault ? Runing In Limp Mode !
    By mck.motors in forum Touran - Sharan - Caravelle
    Last Post: 13-10-2007, 11:58 PM
