Thread: allroad suspension
  1. allroad suspension
    Jun 2012
    whitland uk
    7 Post(s)
    hi all have another a6 c7 allroad suspension issue ..again!!
    i changed all 4 wheels ...and forgot to put suspension in wheel change mode.now have a "suspension fault" on dash .
    garage put it on computer .and came up with code c1031f1
    "level control pressure sensor residual pressure for lowering rear suspension too low" ? suspension goes up good but does not want to go all the way down.but seems to correct itself when i restart car and drive. any ideas what i might have damaged ? could it be a level sensor maybee ?
  2. Re: allroad suspension
    1840 Post(s)
    I had this on an type 4H A8 a few weeks ago, the rear suspension refused to go down, even with the air lines to the valve block disconnected, it had come to a motor trade friend of mine from a car trader friend of his via an auction. The only way we could get it to come down was to drill a hole in each air bag so they could be removed and replaced with two new struts at nearly £2k each... At least 4G air bags can be replaced.
  3. Re: allroad suspension
    Jun 2012
    whitland uk
    7 Post(s)
    Quote Originally Posted by chris.d View Post
    also if i change both rear sensors do i need to do any other adjustments or is it just a case of replacing them
  4. Re: allroad suspension
    1840 Post(s)
    You must do the basic settings
  5. Re: allroad suspension
    Jun 2012
    whitland uk
    7 Post(s)
    hi crasher thanks
    do you mean just clear faults after replacing sensors ?
  6. Re: allroad suspension
    1840 Post(s)
    The four corner heights have to be entered into the level control unit
  7. Re: allroad suspension
    Jun 2022
    Sheffield
    Hi all, newbie here...
    Can anyone tell me the ride heights on all four wheels, have a A6 C6 allroad 2011, recently replaced N/S front airbag, had the calibration done but the O/F front looks too high in all of the modes
    Chris
  1. Question Allroad Suspension
    By Boy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-05-2020, 06:54 PM
  2. Allroad suspension
    By Darren James in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-08-2016, 08:16 PM
  3. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  4. Air Suspension on Non-Allroad?
    By seventh-heaven in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-12-2013, 05:53 PM
  5. Allroad suspension
    By murdochcg in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-06-2009, 11:15 AM
