Thread: Q7 3.0tdi bug no start
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
  1. Q7 3.0tdi bug no start
    May 2022
    Hereford
    Hello
    I have bought a Q7 from Copart that needs some work. I stupidly thought it was a runner with suspension issues. However the car has not run. I will make a shortlist below of work done and see if anyone has any ideas as any help will be appreciated.
    So work as follows,
    Car scanned with VCDS and found a J17 fault, found a broken wire under the relay which was fixed and problem persisted. Checked the in tank pump and found one of the suction pipes was loose from it’s fitting to the lift pump. Upon further inspection I found the same wire to be broken on the ecu side of the loom. With that fixed I was getting power to the lift pump.
    Ran the pump a few times with VCDS to bleed the fuel system. This was not getting rid of the air in the clear feed to the hpfp. So after a bit of Googling I got to the point of bleeding the fuel system manually whilst the engine is cranked. First the right rail (looking from the front) then the left rail. This cleared the air from the hpfp feed line.
    With this I was getting 0.0 or 7.1bar on the when reading the mvb.
    Fitted a new fuel filter (Mahle) and re bleed the fuel system. Upon inspection there was no swarf in the filter
    Car still wouldn’t start.
    Whilst cranking builds pressure upto 500+bar
    When the pressure gets high enough I can hear the injectors click as they fire.
    Tried the car on easy start and got it to fire but cuts out straight away so not sure fuel is getting to the injectors.
    Tried a new starter (will do a write up if any interest) as the car was cranking slowly 120-150rpm. Still no change much better crank.
    I don’t have any pressure gauges so can’t measure actual pressure.
    Car doesn’t lock of the keys remote fob. I have ordered a pick set so I can remove the drivers door lock (seems stuck solid) so I can try and get the key to code. Hopefully this will rule out immobiliser (no lights on dash)
    So next I am going to measure the resistance on the n276 to see if that’s in spec
    Has anybody got any ideas?
  2. Re: Q7 3.0tdi bug no start
    1840 Post(s)
    Sound like a right dog, could you post the full VCDS scan including the VIN.
  3. Re: Q7 3.0tdi bug no start
    May 2022
    Hereford
    Hi Crasher. I will attach a full scan later this evening as I am on mobile at the minute.
    Is there a preferred way to post it or just copy and paste
  4. Re: Q7 3.0tdi bug no start
    1840 Post(s)
    In advanced reply second row next to last there is a # button that gives you [code] [\code]
    Code:
    code read
    if you paste the read in between the ] and [/ it will box it nicely but if you can't work it out, someone will tidy it up.
  5. Re: Q7 3.0tdi bug no start
    May 2022
    Hereford
    Hello Crasher if all has worked well it should be wrapped nicely
    Code:
    Monday,02,May,2022,14:28:35:41467VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
    Data version: 20220407 DS337.0
    www.Ross-Tech.com
    VIN: WAUZZZ4L57D084175   License Plate:
    Mileage: 174810km-108621mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
              55 56 61 62 67 6D 6F 72 76 77
    VIN: WAUZZZ4L57D084175   Mileage: 174810km-108621miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    67-Voice Control -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 4L0 910 401 M    HW: 4L0 907 401
       Component: 3.0L V6TDI   000AG  0030
       Revision: --H10---    Serial number:
       Coding: 0011775
       Shop #: WSC 09308 004 1048576
       VCID: 2C0A6C0ECA0128DB437-8078
       VINID: 9D196AAAA11C147500204047140B60C1B2
    2 Faults Found:
    004501 - Fuel Pressure Regulator Valve (N276)
                   P1195 - 001 - Open or Short to Ground - MIL ON
                 Freeze Frame:
                        Fault Status: 11100001
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 0.0 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 12.31 V
                        Pressure: 0.0 bar
                        Duty Cycle: 7.5 %
    005658 - Glowplug for Cylinder 1 (Q10)
                   P161A - 001 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01100001
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:22:08
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 0.0 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 12.62 V
                        Duty Cycle: 15.0 %
                        Temperature: 10.8∞C
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No SW: 09D 927 750 FS    HW: 09D 927 750 FS
       Component: AL 750 6A           1000
       Revision: 00H64000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: 045AE4AE0211009BEB7-8050
    No fault code found.
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 B    HW: 4L0 614 517 F
       Component: ESP ALLRAD MK25E1   0010
       Revision: 00H30001
       Coding: 0038033
       Shop #: WSC 29027 001 1048576
       VCID: 2904951AC5F33DF3B81-807C
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:25:04
                 Freeze Frame:
                        Count: 0
                        Count: 325
                        Count: 297
                        Count: 45824
    Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100653491
       Coding: 0000147
       VCID: 6398C732E75FA7A3B2D-8036
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 731 C    HW: 4E0 035 729
       Component: Interfacebox    H43 3450
       Revision: 00000000    Serial number: 386BL077531043
       Coding: 0002002
       VCID: 2802901EDEF904FBA7F-807C
       Subsystem 1 - Part No: 4L0 910 609
       Component: E0380 BedienteilH01 0060
       Subsystem 2 - Serial number: 00000000657388
       Subsystem 3 - Serial number: 0101.02.070000000100011518ˇ
       Subsystem 4 - Serial number: 011518ˇ
    Address 08: Auto HVAC        Labels: None
       Part No SW: 4L0 910 043     HW: 4L0 820 043 F
       Component: KLIMABETAETIGUNGH05 0060
       Revision: 00---012    Serial number: 00000030026859
       Coding: 0001046
       VCID: 6194CD3AFD43B5B3A01-8034
    1 Fault Found:
    01592 - Air Quality Sensor (G238)
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:25:08
                 Freeze Frame:
                        Temperature: 13.0∞C
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H17 0240
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0013121
       VCID: 31347D7AED234533701-8064
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H08 0080
       Coding: 00064792
       Shop #: WSC 31414
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00150059
       Shop #: WSC 31414
    Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
       Part No SW: 4L0 910 110 A    HW: 4L0 035 110
       Component: MP3-Changer     H43 0350
       Revision: 00043000    Serial number: AUZ5ZBG1035498
       Shop #: WSC 00000 000 00000
       VCID: 1D6CB1CA81BBD153C49-8048
    Address 15: Airbags        Labels: 4L0-910-655.lbl
       Part No SW: 4L0 910 655 B    HW: 4L0 959 655
       Component: 31 AIRBAG AUDI8RH39 0120
       Revision: 06H39000    Serial number: 0037GD08A38P
       Coding: 0013105
       Subsystem 1 - Serial number: 6332QSME1858355DN
       Subsystem 2 - Serial number: 6342QSME184D4541G
       Subsystem 3 - Serial number: 6352QSME200115770
       Subsystem 4 - Serial number: 6362QSME1D6E1F3D1
       Subsystem 5 - Serial number: 63734SME1E132D1D6
       Subsystem 6 - Serial number: 63834SME1F7C3369F
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenks‰ulenmodul H08 0230
       Revision: 00H08000    Serial number: 90026070250632
       Coding: 0102042
       VCID: 669EDE26146DD28B553-8032
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
       Component: KOMBIINSTR. M73 H18 0170
       Revision: 00100000    Serial number: 5HJ317827
       Coding: 2657448
       VCID: 23188732A7DFE7A3F2D-8076
    Address 18: Aux. Heat        Labels: 4L0-910-105.clb
       Part No SW: 4L0 910 105     HW: 4L0 815 071 H
       Component: Heizgeraet      H10 0140
       Revision: 0000000A    Serial number: 00000009024928
       Coding: 0000001
       VCID: 6092C83EF649BCBBAFF-8034
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B071248487
       Coding: F55BBE7F307202
       Shop #: WSC 00720 210 91846
       VCID: 6C8AAC0E0A81E8DB037-8038
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 C    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7660
       Revision: --H03001    Serial number: 15.1528-0095.2
       Coding: 0015510
       Shop #: WSC 50981 003 1048576
       VCID: 2A066A16C0F536EBB1B-807E
    2 Faults Found:
    01575 - Control Switched Off
                000 - -
                 Freeze Frame:
                        Fault Status: 11100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:25:04
                 Freeze Frame:
                        Error Code: 69
    01316 - ABS Control Module
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 11101101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:25:05
                 Freeze Frame:
                        Error Code: 98
    Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
       Part No SW: 4E0 910 887 T    HW: 4E0 919 887 L
       Component: MNS ECE         H48 1030
       Revision: 00000000    Serial number: 399AR077557011
       Shop #: WSC 00673 210 83197
       VCID: 3E2E56462C7DAA4BFD3-806A
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00000000    Serial number: w9
       Coding: 0002651
       VCID: 2F307B02FB1753C3665-807A
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:25:04
    Address 46: Central Conv.        Labels:. 4L0-910-289.lbl
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01032522540000
       Coding: 7348475
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H10 0240
       Revision: PROD_01     Serial number: 00000000043576
       Coding: 0000112
       Shop #: WSC 02324 758 00200
       VCID: 251C992AA9EB19939C9-8070
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
                000 - -
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:25:10
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000031847
       Coding: 0011101
       VCID: 5EEEF6C6CC3D8A4B9D3-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00000000    Serial number: óB
       Coding: 0002651
    Address 55: Headlight Range        Labels: 4F0-910-357.lbl
       Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
       Component: AFS 1           H01 0020
       Revision: 00000001    Serial number:
       Coding: 0000022
       Subsystem 1 - Part No: 7L6 941 329 A
       Component: AFS-Modul links H06 0002
       Subsystem 2 - Part No: 7L6 941 329 A
       Component: AFS-Modul rechtsH06 0002
    Address 56: Radio        Labels: 4E0-910-541.lbl
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 388AR077588000
       Coding: 0000001
       VCID: 2E0E6606FC1D5ACB6D3-807A
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000003360
       VCID: 649AC42EE251A09B4B7-8030
       Subsystem 1 - Part No: 4F0 915 105 D
       Component: von VA0  610402092
       Coding: 344630393135313035442056413036313034303230393220
       Shop #: WSC 00011 888 06946
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 159
                        Mileage: 174816 km
                        Time Indication: 0
                        Date: 2022.05.02
                        Time: 14:25:03
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Component: TSG HL          H21 0050
       Coding: 0002058
    Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000701150081
       Shop #: WSC 12336 024 394758
       VCID: 363E4E66044D620B253-8062
    Address 6D: Trunk Elect.        Labels: 4L0-910-945.clb
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 1 - Part No: 4L0 910 946
       Subsystem 2 - Serial number: E5030100B
       Subsystem 3 - Serial number: RD07.02.07--H21001000C0040ˇ
       Subsystem 4 - Serial number: 0C0040ˇ
    Address 6F: Centr. Conv. II        Labels:. 4L0-910-290.lbl
       Part No SW: 4L0 910 290     HW: 4L0 907 290
       Component: ILM HINTEN 2    H05 0060
       Revision: AAH05061    Serial number: 002384930-----
       Coding: 0000001
       VCID: 659CD92AE96BD9935C9-8030
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Component: TSG HR          H21 0050
       Coding: 0002058
    Address 76: Park Assist        Labels: 4Fx-910-283.lbl
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06330702715652
       Coding: 0201046
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007626694
       Coding: 0010900
    End----------(Elapsed Time: 02:03, VBatt start/end: 12.7V/12.8V)-----------
    1 1 0
  6. Re: Q7 3.0tdi bug no start
    Mar 2010
    Derry ireland
    60 Post(s)
    Can you post up your engine code it would certainly be helpfull to your problem
  7. Re: Q7 3.0tdi bug no start
    1840 Post(s)
    Vehicle Identification No. WAUZZZ4L57D084175
    Model Audi Q7 qu. 3.0 TDIAQ7
    Date of production 14.02.2007
    Year 2007
    Sales type 4LB0ML
    Engine Code BUG
    Transmission Code JXX
    Exterior colour code LZ7L
  8. Re: Q7 3.0tdi bug no start
    1840 Post(s)
    I will look at the wiring diagram in the morning
  9. Re: Q7 3.0tdi bug no start
    May 2022
    Hereford
    Engine code is in the title. Bug
  10. Re: Q7 3.0tdi bug no start
    May 2022
    Hereford
    Thanks Crasher.
  1. Question 2.0Tdi BRE No Start
    By Stevewr1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-07-2020, 02:18 PM
  2. Please Help A3 2.0tdi bkd stalled won’t start
    By gcq7 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-05-2020, 09:13 PM
  3. A4 S-Line 2.0tdi won't start
    By farmerferret in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-02-2018, 01:04 PM
  4. Please Help 2.0TDI - wont start
    By brummieboy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-06-2013, 10:21 PM
  5. 2.0tdi cranking but won't start..
    By Messer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-12-2012, 10:13 PM
