Thread: Warm/hot start problem
  1. Warm/hot start problem
    Dec 2021
    Turkey
    Dear all,
    I got a 3.0 TDI and i refurbished my engine at 400K km. And since then I had this warm start problem.
    That is; when my engine is cold, in the morning for example, the engine's first and following starts are fine. But after a ride, engine warms up, i stopped the car for a 10 or 15 minutes stop for example. After that engine starts hesitantly.
    The hesitation is much like a poor battery. But, as i said before, cold starts are always fine. If the engine is warm, 90 percent of starts is hesitantly. My battery is brand new btw.
    It can be an electrical issue, because when the problem first occured an electrician guy helped to engine to start smoothly by an external battery. But my battery is new. And problem mostly occurs when the engine is hot.
    Something takes too much current during startup when the engine and/or the itself is hot. Is there anybody who experienced the same or similar problem?
    And is there any diagnostics to debug the starter motor?
    Thanks in advance.
  2. Re: Warm/hot start problem
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Leaking injectors?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Warm/hot start problem
    Jul 2008
    Lisburn
    15 Post(s)
    I though injectors but the OP has said it starts of a battery pack ok.
    So i would check the jump start connections as theses can suffer from corrosion I have read on here.
    it sounds like you have a poor connection somewhere, cold contracts and makes it good. so i am still thinking the jump start locations as they would see the most heat change.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: Warm/hot start problem
    Dec 2021
    Turkey
    Problem solved! If there is anybody who has similar symptoms with his/her car, message me.
    Regards
  5. Re: Warm/hot start problem
    Dec 2007
    43 Post(s)
    You could just put the solution below, as chances are by the time someone else has the issue you wont be active any more.
  1. GT TDI 05 warm start problem
    By gizziet in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2013, 06:51 PM
  2. Please Help Warm start problem
    By hx31192 in forum Octavia
    Last Post: 08-02-2010, 09:07 PM
  3. Question warm start problem
    By motorhead1 in forum Alhambra
    Last Post: 07-10-2008, 09:46 PM
  4. Did you ever have this warm start problem ?
    By jojotogo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-01-2008, 02:09 PM
  5. Warm Start A4 Problem!!
    By orrinrob in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2007, 10:58 PM
